Clipper 343 Posted July 16, 2010 Share Posted July 16, 2010 I have a couple of secondhand plastic ABS hatches that are pretty grubby and have paint and rust stains on them. Can anyone advise what cleaners or solvents might help? (and what should be avoided) Link to post Share on other sites
Guest Posted July 17, 2010 Share Posted July 17, 2010 I'd go back to the previous owner and demand my money back Link to post Share on other sites
Clipper 343 Posted July 17, 2010 Author Share Posted July 17, 2010 The price was extremely reasonable, and we started drinking it, so no help there. Was more wondering if Iwould damage the plastic if I tried to clean with acetone, or would jif help, or something like that. Link to post Share on other sites
wheels 543 Posted July 17, 2010 Share Posted July 17, 2010 Keep solvents away from the stuff. Although ABS can stand most of them, it actually causes the plastic to become brittle and easily broken later on. But Acetone is one that will damage the surface and actually can result in driving the dirt deeper in and harder to remove. Try the Gelcoat stain removers. I know that will at least handle the Rust stains. the other stains I am not so sure. It depends on what has made them. Mr Muscle Cold Oven cleaner does magic with many stains and won't hurt the plastic and yes the Jiff maybe worth a try as it is a mild scourer. Otherwise maybe a cutting compound as used on Gelcoat. Treat it a little likeGelcoat and you won't go far wrong. Link to post Share on other sites
rigger 47 Posted July 17, 2010 Share Posted July 17, 2010 do not think it would work for rust stains but for lifting paint I used eucalyptus oil on some plastic fittings - did not appear to damage the plastic Link to post Share on other sites
tuffyluffy 76 Posted July 17, 2010 Share Posted July 17, 2010 Soak em in a tub of Nappisan, if that doesnt work, try household bleach Link to post Share on other sites
Clipper 343 Posted July 17, 2010 Author Share Posted July 17, 2010 Thanks guys, some interesting suggestions! Link to post Share on other sites
SloopJohnB 323 Posted July 17, 2010 Share Posted July 17, 2010 Buy a new boat.........not stains Link to post Share on other sites
Guest Posted July 20, 2010 Share Posted July 20, 2010 Dishwasher powder also works a treat... Link to post Share on other sites
Guest Dry Reach Posted July 20, 2010 Share Posted July 20, 2010 Dishwasher powder also works a treat... For rust stains the best is Oxalic Acid, available from your chemistg. Also you can cut and polish ABS but use a very fine cutting compound. to whiten if return to original colour... Peroxide Method (for ABS plastic) You Will Need: Hydrogen peroxide Oxy laundry booster Sunshine or UV light Water Bucket or large bowl Rubber gloves Goggles Steps to Whiten the Plastic: Begin by protecting yourself with rubber gloves and goggles. Fill the bucket with hydrogen peroxide. Add ¼ teaspoon of Oxy laundry booster for each gallon of peroxide. Place the yellowed plastic pieces into the solution and allow them to soak. The soaking time will vary with most pieces whitening in 2-6 hours. The mixture will last for up to four days before it needs to be replaced. Retr0Bright has also developed a way to make this into a gel that can be spread onto the plastic. This is especially helpful for larger items. Set the items under a UV light or out in the sunshine. When the item has reached the desired whiteness, remove and rinse thoroughly to remove any remaining cleaning products. If necessary, wash with dish detergent and water. Additional Tips and Ideas While bleach can be an effective color remover, it may weaken the plastic over time. Also there are good Automotive systems for painting them. Link to post Share on other sites
