international toplac
anyone used this yet? can get some brightside for about 1/2 price and wondering if it is worth spending the extra for the toplac instead. painting my 3.7 - have undercoated already so anything 2 pack not really an option
cheers
dan
There is nothing wrong with the Brightside but it is a product not being made anymore so if you need to do a touch up getting the same colour will be an issue. Toplac has better UV properties and is more durrable, you can paint Toplac over Brightside without too much hassle so re-coating will be fairly easy.
Guest Dry Reach
Read this!
MATERIAL SAFETY DATA SHEET Sales Order: {SalesOrd}
TOPLAC ROCHELLE RED
MSDS Revision No: F2 -6
MSDS Revision Date: 11/06/2002
EMERGENCY NUMBERS:
(800) 424-9300 CHEMTREC (USA)
International Paint Inc.
2. HAZARDOUS INGREDIENT INFORMATION
CAS No. Ingredient Name & % Source Exposure Data
002786-76-7
2-Naphthalenecarboxamide,
4-[[4-(aminocarbonyl)phenyl]
azo]-N-(2-ethoxyphenyl)-3-
hydroxy-
1.0 - 10% by Weight
OSHA: No Data Available
ACGIH: No Data Available
NIOSH: No Data Available
Supplier: No Data Available
OHSA,
CAN: No Data Available
Mexico: No Data Available
Brazil: No Data Available
Source Health Data
Source Carcinogen Data
OSHA: Select Carcinogen: No
NTP: Known Carcinogen: No; Suspected Carcinogen: No
IARC:
Group 1: No; Group 2A: No;
Group 2b: No; Group 3: No; Group 4: No
YKS299_F2 Page 2 of 7
file://C:\tmp\TOUTPUT.HTM 11/18/02
008052-41-3
Stoddard solvent
25 - 50% by Weight
OSHA: 500 ppm TWA; 2900 mg/m3 TWA
ACGIH: 100 ppm TWA
NIOSH: 350 mg/m3 TWA1800 mg/m3 Ceiling20,000 mg/m3 IDLH
OHSA,
CAN: 525 mg/m3 TWAEV (140 Degree C Flash Aliphatic Solvent)
Mexico:
100 ppm TWA; 523 mg/m3 TWA200 ppm STEL; 1050 mg/m3
STEL
Source Health Data
NIOSH: Eye nose
IARC:
064742-88-7
Solvent naphtha (petroleum),
medium aliphatic
1.0 - 10% by Weight
OHSA,
Source Health Data
IARC:
064742-95-6
Petroleum naphtha, light
aromatic
OHSA,
YKS299_F2 Page 3 of 7
064742 95 6
1.0 - 10% by Weight Source Health Data
IARC:
129757-67-1
Decanedioic acid, bis(2,2,6,6-
tetramethyl-4-piperidinyl) ester,
reaction products with tert-Bu
hydroperoxide and octane
1.0 - 10% by Weight
OHSA,
Source Health Data
IARC:
3. HAZARD IDENTIFICATION
Overview:
NOTICE: Reports have associated repeated and prolonged occupational overexposure to solvents
with permanent brain and nervous system damage. Intentional misuse by deliberately concentrating
and inhaling the contents may be harmful or fatal. Avoid contact with eyes, skin and clothing.
Inhalation: May be harmful or fatal if inhaled. Causes nose and throat irritation. Vapors may affect the brain or
nervous system causing dizziness, headache or nausea.
Eyes: Causes severe eye irritation. Do not get in eyes.
Skin: Causes skin irritation. May be harmful if absorbed through the skin.
Ingestion: Harmful if swallowed. May cause abdominal pain, nausea, vomiting, diarrhea, or drowsiness.
Chronic Effects:
Contains an ingredient which can cause organ damage (See Section 2 and Section 15 for each
ingredient). Possible cancer hazard. Contains an ingredient which may cause cancer based on animal
data (See Section 2 and Section 15 for each ingredient). Risk of cancer depends on duration and level
of exposure.
HMIS Rating: Health: Unknown Flammability: Unknown Reactivity: Unknown
ester/ urethane modified short oil Alkyd.
Nice chemistry and will out perform normal Long oil or other standard Alkyd emanels.
looking at the volume solids and the chemistry it is probably the best enamel on the market.
Guest Dry Reach
Or in english for the plebs!
PRODUCT DESCRIPTION
Toplac is a premium gloss marine enamel for all substrates above the waterline. It is exceptionally easy to apply by brush or roller and pad and contains UV filter for increased durability.
* Excellent flow characteristics
* Range of bright colours
* Over twice the life of ordinary alkyd enamels
Its unique chemical structure enables Toplac to outperform traditional finishes giving a long lasting high definition gloss.
PRODUCT INFORMATION
Colour YKA027-Cream, YKA184-Med. White, YKA187-Ivory, YKA241-Norfolk Green, YKA265,YKA504-Fire Red, YKA905-White 905, YKA923-Squall Blue, YKB000-Snow White, YKB914-Baltic Blue, YKB993-Oxford Blue, YKE938-Danube Blue, YKF684-Atlantic Grey, YKF991-Mauritius Blue, YKJ292-Bounty, YKS101-Yellow, YKS299-Rochelle Red, YKS936-Lauderdale Blue, YKT541-Donegal Green, YKU898-Bondi Blue, YKY999-Jet Black, YKZ501-Rustic Red . Refer to colour chart for further details.
Finish High Gloss
Specific Gravity 1.1
Volume Solids 51%
Typical Shelf Life 2 yrs
VOC (As Supplied) 404 g/lt
VOC (EU Solvent) 367.3 g/kg EU Solvent Emissions Directive (Council Directive 1999/13/EC)
Unit Size 750 ml 375 ml (some colours only) 2.5 Lt (some colours only)
DRYING/OVERCOATING INFORMATION
Drying
5°C 15°C 23°C 35°C
Touch Dry [iSO] 6hrs 3hrs 2hrs 1hrs
Overcoating
Substrate Temperature
5°C 15°C 23°C 35°C
Overcoated By Min Max Min Max Min Max Min Max
Toplac 24hrs 4days 16hrs 3days 8hrs 2days 6hrs 1days
APPLICATION AND USE
Preparation PREVIOUSLY PAINTED SURFACES:
In Good Condition: Wash down with a suitable detergent, rinse with fresh water and allow to dry. Abrade with 280-320 grade (grit) paper.
In Poor Condition: Remove all previous coatings and prime the substrate.
PRIMING: Substrate preparation is covered separately on the primer datasheet.
BARE WOOD: Sand smooth with 80-180 grade paper and then 280 grade paper. Remove sanding dust by brushing, dusting and wiping. If wiping with solvent then allow to dry completely before applying products recommended for application direct to wood (see specific coating systems). Prime with Yacht Primer or Clear Wood Sealer Fast Dry.
STEEL: Degrease with solvent or Super Cleaner. Gritblast to Sa 2½ - near white metal surface. If gritblasting is not possible, grind the metal surface with 24-36 grit abrasive discs to a uniform, clean, bright metal surface with a 50-75 microns anchor pattern. Use angle grinder on small areas. Clean thoroughly and allow to dry. Prime with Yacht Primer.
ALUMINIUM: Degrease with solvent or Super Cleaner. Sand well using 60-120 grade (aluminium compatible) paper. Clean thoroughly and allow to dry. Prime with Yacht Primer as soon as possible (within 8 hours).
GRP: Degrease with solvent or Super Cleaner. Sand well using 180-220 grade paper. Clean thoroughly and allow to dry. No primer required - apply Pre-Kote direct to GRP.
AGED/WEATHERED GELCOATS: Due to the potentially porous nature of aged/weathered gelcoats the risk of solvent/moisture entrapment after painting is much higher than when gelcoat is new. As a result this entrapment could lead to blistering of the paint film. To reduce the risk of paint film blistering it is recommended that 3 coats of Interprotect are applied to seal the gelcoat. Interprotect must be overcoated with Perfection Undercoat prior to topcoat application.
ALL SUBSTRATES: Use Pre-Kote undercoat. If spray applying Toplac, Pre-Kote must be aged a minimum of 14 days. If this is not possible Perfection Undercoat can also be used as an undercoat.
Method Sand the undercoat smooth with 320-400 grade (grit) wet or dry paper. Remove dust with a dust wipe. Apply 1-2 coats.
Hints Mixing Stir well before use.
Thinner Thinner No.1 Thinner No.10 #NAME?
Thinning In warm or windy conditions up to 10% of thinner may be added to ease application.
Cleaner Thinner No.1
Ventilation and Humidity Control Apply in dry, well ventilated conditions. Avoid applying late in the evening as condensation can cause a loss of gloss overnight.
Conventional Spray Thin 10-25% with Thinner No.10 (For Professional use ONLY) to a viscosity of 18-22 secs (BS4) or 16-20 secs (DIN4). Pressure: 3-4 bar. Tip Size: 1.1-1.4 mm. NOTE: Pre-Kote undercoat MUST be aged a minimum of 14 days before application of Toplac. SPRAY APPLICATION - PROFESSIONAL APPLICATORS ONLY.
Other For lighter colours, mix the first coat of finish 50:50 with the undercoat to improve the depth of colour and opacity. For best results when applying by roller, smooth off with a pad or brush.
Some Important Points Toplac may discolour if used at temperatures above 80°C. Not suitable for permanently immersed surfaces. Do not use below 5°C. Ambient temperature should be minimum 5°C/41°F and maximum 35°C/95°F. Product temperature should be minimum 15°C and maximum 35°C. Substrate temperature should be minimum 5°C/41°F and maximum 35°C/95°F. Avoid applying late in the evening as condensation can cause a loss of gloss during overnight cure.
Compatibility/Substrates Use over suitably prepared and undercoated surfaces or existing paint schemes.
Number of Coats 1-2 by brush
Coverage (Theoretical) - 13.33 (m²/lt)
(Practical) - 12.00 (m²/lt) by brush, 8 m²/lt by spray
Recommended DFT 38 microns dry
Recommended WFT 75 microns wet
Application Methods Brush, Conventional Spray, Roller
Guest Dry Reach
Compared to Altexs Urethane Mod'd Enamel...
• High gloss enamel finish
• Marine quality
• Good weathering properties
• Good gloss retention
• Good application characteristics
Marine Gloss Enamel is designed for use as the
finishing coating for the Single Component Marine
topsides system.
Marine Gloss Enamel can also be used :
• For signwriting and boot stripes
• For up-grading existing enamel systems, subject to
correct preparation and undercoating
• On canoes, tenders, dinghies, trailer yachts and power
boats
Marine Gloss Enamel
Reinforced Alkyd Enamel
Generic Type: Polyurethane Modified Gloss
Finish
Colour: refer Altex Yacht & Boat Colour
Chart
Packaging: 500ml, 1 and 4 litre
Single component
Gloss: High Gloss
Flash Point: 35oC
Thinner: Mineral Turpentine
Storage: Store under cool, dry conditions
Density: 1.21 kg per litre
Volume Solids: 50%
Theoretical Coverage Rate:
10 sq metres per litre at 50 microns dry
Recommended Film Thickness Per Coat:
80-100 microns wet to obtain 40-50 microns dry
Application: Spray, brush or roller
Dry Times (50 μm DFT / 25oC / 50% RH):
Touch Dry : 1½ Hr
Hard Dry : Overnight
Recoat Time (50 μm DFT / 25oC / 50% RH):
Recommended : Overnight
Marine Gloss Enamel August 2008
Head Office
New Zealand
91 - 111 Oropi Road
Greerton, Tauranga
PO Box 142
Tauranga Mail Centre
Phone: +64 7 5411 221
Fax: +64 7 5411 310
www.altexcoatings.co.nz
Head Office
Australia
7 Production Avenue
Ernest Junction
Queensland 4214
Australia
Phone: +61 7 5594 9522
Fax: +61 7 5594 9093
www.altexcoatings.com.au
DISCLAIMER
This is not a specification and all of the information is given in good faith. Since conditions of use are beyond the
control of the manufacturer, information contained herein is without warranty, implied or otherwise., and final
determination of the suitability of any information or material for the use contemplated, the manner of use and whether
there is any infringement of patents is the sole responsibility of the user. The manufacturer does not assume any
liability in connection with the use of the product relative to coverage, performance or injury. For application in special
conditions, consult the manufacturer for detailed recommendations.
ALTEX COATINGS LIMITED
SURFACE PREPARATION
DIRECTIONS FOR USE
PRECAUTIONS
Marine Gloss Enamel is designed to be applied over
Marine Surfacer Undercoat.
All surfaces must be clean and dry before application of
Marine Gloss Enamel. If the previous coating is aged more
than one (1) week it should be thoroughly sanded and/or
treated with P40 Prepainting Cleaner prior to application of
DO NOT sand using stearate coated paper as this may
adversely affect the adhesion of subsequent coatings.
Mixing:
Marine Gloss Enamel is a single component product that
requires thorough mixing and careful thinning before use.
Thinning:
For spray application Marine Gloss Enamel should be
thinned 15% to 40% with mineral turpentine. For brush
application thin 5% to 15% with mineral turpentine,
Application:
Marine Gloss Enamel may be applied by spray, brush or
roller.
Suggested spray equipment is:
Air Spray Graco - Delta Air Spray; 1.1 - 1.4 mm
Fluid Nozzle
De Vilbiss - JGA gun, E Fluid Nozzle,
704 Air Nozzle
Airless Spray Graco - King 30:1 pump; 0.011-0.013”
Fine Finish Tip
(Note : Other equipment equivalent to the above may be
used.)
Note: Certain colours may require more than one coat to
achieve complete hiding of the substrate.
Clean-up:
Use Mineral Turpentine
Both Good!
Guest Dry Reach
So house paint will be alright then. :lol: :lol: :lol:
You can use anything you like! but it comes at a cost.
If i was the 3.7 guy above i would sand the undercoat of and go 2 pack urethane system.
But each to their own.
Yes there are the "rumours" of same paint coming from same Vats, and that was the case many years ago in the Enamel ranges of several manufacturers. But paint technology has come a very long way now and those stories are not true for the big manufacturers at least.
Enamel paint is no longer just a plain simple Turps based paint. They have all sorts of complex curing and hardening agents in them now. If you know what to look for, they are listed in the specs DR has posted above. Many single pot paints are as hard wearing as the older two pots used to be. But the two pots have gone forward leaps and bounds no as well. A lot in the area ease of application, making them some what safer for the amature to apply, what ranges of temp and moisture they can be applied in and recoat times and of course one of the real biggies, is the Gloss that can be achieved, even with a roller and brush.
The gap between longevity of single and two pots is still there. But the ability to hold their looks for a longer period has been extended.
However, all that is seconded always to some basic facts. What the subsrate is for a starter. In fact, most paints will fail due to what they are stuck to deteriorating rather than the coating itself. No point in putting an expensive two pot on if you are going to have plain ole ply warp and crack and open up due to no protection of the ply. No point in applying any expensive top coat if you do not prepare the surface correctly. Not point in the expensive top coats if you do not apply the correct primers and undercoats etc. And certainly no point in applying anything if you do it in the wrong temps, wrong drying times and wrong Humidities.
Here is another company to consider. I really really like their products and not because the owner of the NZ branch is a mate of mine. And no I don't get any benifits from placing this here.
http://www.hempel.com/Internet/inecorpo ... enDocument
Guest Dry Reach
Yip :thumbup: but i think you will find that some companies are relabelling alot of products from one batch (formula) into many various labels
ie - Pleasure marine, Commercial marine, Industrial - Most Marine products
In the early house paint days they used to take a commone premium product and re labell it into the trade, and house branded (Mitre 10) cans.
I suspect that some companies are still doing this and the way to find out is to check their MSDS and volume solids figures in particular.
