paxfish 5 Posted March 3, 2015 Share Posted March 3, 2015 Guys, I have a chip in my prop blade, and I'm thinking of getting a higher pitch on it's replacement. For those of you running a GBE or similar, what pitch are you running on your 9.9hp? My rig is 2800 to 3800 pounds GBE variant with a 9.9 Yamaha four stroke "high thrust" and a 11 3/4" by 9" pitch prop. Top speed is about 7 knots with a clean bottom. Thanks! Quote Link to post Share on other sites
ScottiE 174 Posted March 3, 2015 Share Posted March 3, 2015 I'm interested in this as well. I get about 7-8kts with my 8hp merc long shaft with the stock prop. boat is only 1000kg Quote Link to post Share on other sites
Ed 143 Posted March 4, 2015 Share Posted March 4, 2015 Hi paxfish, A lot of the boats here run 2 stroke 8 HP as that is the lightest motor they can carry for racing, and would be propped slightly differently. Personally On my GBE I have a newer version of your motor with the high thurst as well. My logic is that I am happy to sacrifice a knot or two of top speed in return for very positive response while manoeuvring and the knowledge that if the weather is bad there is heaps of low speed grunt on tap to get out of a sticky situation Cheers Quote Link to post Share on other sites
BNG 44 Posted March 4, 2015 Share Posted March 4, 2015 Keep the old chipped one on board, if its the rubber bushed version they can spin the bush out and will (maybe, if your really lucky) still motor at bugger all revs only. Usually happens when you dont want it to happen, short chop, lee shore, semi darkness, raining, family on board, cruising, etc. So nice to have the old one with a fair dinkum bush on board. Quote Link to post Share on other sites
paxfish 5 Posted March 4, 2015 Author Share Posted March 4, 2015 Keep the old chipped one on board, if its the rubber bushed version they can spin the bush out and will (maybe, if your really lucky) still motor at bugger all revs only. Usually happens when you dont want it to happen, short chop, lee shore, semi darkness, raining, family on board, cruising, etc. So nice to have the old one with a fair dinkum bush on board. Thanks for the responses, Gents! Very Helpful. Especially yours, BNG! P. S. Has anyone seen my down under translator lying about? Quote Link to post Share on other sites
Island Time 1,234 Posted March 4, 2015 Share Posted March 4, 2015 Really elementary prop selection guide. When you boat is clean, but has it's average load on board, your engine should just reach it's max allowable revs (check the manual) under full power in calm conditions. If it does not, it is over-proped, if it reaches max revs with more than a little throttle still available, it is under proped. A little under-proped is good, as it allows for more load and or weather conditions. Be sure you cannot over-rev you motor, esp an outboard or other petrol engine (Diesels are governed and cannot be over rev'd when working properly). Most little outboards don't have a rev counter, but you can get one pretty cheaply, including handheld optical ones for testing, not permanent install. Or borrow one. Correct prop sizing is good for your engine, gives best economy, and best boat speed under power. It is worth the effort! Finally, if you have a prop with a bush that has died, and you need a temp solution, a couple of screws thru the hub into the bush often works for a while, provided the failure is the outside vulcanising..... NOT a permanent solution!! As BNG said, carry a spare prop. Quote Link to post Share on other sites
Adrianp 119 Posted March 4, 2015 Share Posted March 4, 2015 Keep the old chipped one on board, if its the rubber bushed version they can spin the bush out and will (maybe, if your really lucky) still motor at bugger all revs only. Usually happens when you dont want it to happen, short chop, lee shore, semi darkness, raining, family on board, cruising, etc. So nice to have the old one with a fair dinkum bush on board. Happened to us last year of a windy day when we had broken half the slugs off the main. Ended up limping to a local yacht club where we had a few rums and waited for the wind to drop before motorsailing home under jib. The props (on 8hp Yamy long shafts anyways) can jump in an out of the water a lot when trying to motor in a chop and I think that busts the bush. Prop selection for our cats is tricky due to the windage we have. We have changed to a prop with reduced pitch which means we can only motor at about 5-6knots in flat water but we get a lot more grip/push when the wind comes in, where the old prop would just labour the motor with the extra load. We have also added one of those trim wing things which has reduced the ventilation problem in a chop. I was very impressed with Ed's 9.9hp motor when I went for a sail with him. It was so quiet that I forgot to turn it off before raising it! The bigger diameter prop gives a good grip on the water. Actually I was very impressed with it until we start sailing and the motor bracket started spraying water at me like a firehose! I hope the electronic switchboard you have in the engine well is well waterproofed as that areas sees a lot of water when sailing. Quote Link to post Share on other sites
paxfish 5 Posted March 5, 2015 Author Share Posted March 5, 2015 Thanks for the comments, Freedom - Yeah - that is a Blue Seas switchbox and it is rated for exposure. I opened it up, hosed down all the contacts with Corrosion X and resealed it. Hopefully it continues to hold up well. That box is for the nav lights. I have a separate system with it's own battery, solar panel and controller to power the GPS and autopilot. Quote Link to post Share on other sites
Tim C 23 Posted March 9, 2015 Share Posted March 9, 2015 For pushing multihulls ( or dare I say any displacement yacht or even small barge) you want big blade area, big diameter and fine pitch. Think of a prop moving through butter like a screw. If you are going fast, say 20-30 knots, which is what most outboards are aimed to do, then you need a course pitch to keep the prop gripping at its high speed through the water. But that same high pitch prop will stall the blades at low speed, especially in reverse. A bit like having your sails over sheeted going downwind. The ideal is 'under square' which is less pitch than diameter, but can be hard to find. Much as I really hate to use anything imperial, you should be looking for a 10" x 8", or 9" x 6" etc. Biggest diameter the motor will take, smallest pitch you can find. The ongoing popularity of a the Yamaha 9.9 as a yacht motor is they are one of the few with a low gear box, a big prop for the motors size, and 'barge pushing' prop options. The real difference is reverse and low speeds. But your yacht can't motor at really high speeds anyway; the hull shape won't let it. PS: Not sure in NZ what a pound is with relation to a boat? Are you a drummer or pile driver?? Quote Link to post Share on other sites
Clive 13 Posted March 9, 2015 Share Posted March 9, 2015 After struggling with pushing Deeds along in strong winds I changed to the smaller of the 2 High Thrust props available for the 8hp Yam. I can now motor in 30 knots which is really nice. Quote Link to post Share on other sites
paxfish 5 Posted March 10, 2015 Author Share Posted March 10, 2015 For pushing multihulls ( or dare I say any displacement yacht or even small barge) you want big blade area, big diameter and fine pitch. Think of a prop moving through butter like a screw. If you are going fast, say 20-30 knots, which is what most outboards are aimed to do, then you need a course pitch to keep the prop gripping at its high speed through the water. But that same high pitch prop will stall the blades at low speed, especially in reverse. A bit like having your sails over sheeted going downwind. The ideal is 'under square' which is less pitch than diameter, but can be hard to find. Much as I really hate to use anything imperial, you should be looking for a 10" x 8", or 9" x 6" etc. Biggest diameter the motor will take, smallest pitch you can find. The ongoing popularity of a the Yamaha 9.9 as a yacht motor is they are one of the few with a low gear box, a big prop for the motors size, and 'barge pushing' prop options. The real difference is reverse and low speeds. But your yacht can't motor at really high speeds anyway; the hull shape won't let it. PS: Not sure in NZ what a pound is with relation to a boat? Are you a drummer or pile driver?? Heh heh - Forgive me. Since I value the input of this board, I do make a respectful effort to convert Imperial to metric with you guys. However I neglected to this time. Tennant's specs are 1230 empty to 1767 kilos (heavy load.) Current prop is 11 3/4" by 9" pitch. I don't know if those units apply down there when it comes to props, so that is 29.8cm by 22.9cm pitch. Basically it is first gear.... Quote Link to post Share on other sites
MartinRF 53 Posted March 10, 2015 Share Posted March 10, 2015 Hmmm, so you have roughly 1 m more waterline than I have and 50% more empty boat weight. My guess you will only see a small speed increase from changing prop -- you are limited by waterline length. At 7 knots I guess you notice transverse waves in your wake. /Martin Quote Link to post Share on other sites
paxfish 5 Posted March 10, 2015 Author Share Posted March 10, 2015 At 7 knots I guess you notice transverse waves in your wake. /Martin It is possible. I'll know more once I get a few more hours on the boat! Thanks again for that link. You've really compiled some interesting information there! Have you had any rot in the core at all? I found and replaced one wet strip thus far. No telling how long it had been wet - probably since the boat was built 12 years ago. But the western red cedar was not rotten at all. Quote Link to post Share on other sites
MartinRF 53 Posted March 10, 2015 Share Posted March 10, 2015 WRC is not very rot prone to start with. My boat is mostly not WRC since we could not find enough of it on the Swedish market back then (30 years ago). I have had no rot problems worth mentioning or remembering but then I have been pretty quick at patching up dents and whatever to stop water ingress and later on made proper repairs. My main head ache has been UV radiation deteriorating things where I have opted for clear finish. Sooner or later the wood-epoxy bond gives... Clear finish 'indoors' is a pretty good idea though since it facilitates inspection. /Martin Quote Link to post Share on other sites
Tim C 23 Posted March 10, 2015 Share Posted March 10, 2015 Heh heh - Forgive me. Since I value the input of this board, I do make a respectful effort to convert Imperial to metric with you guys. However I neglected to this time. Tennant's specs are 1230 empty to 1767 kilos (heavy load.) Current prop is 11 3/4" by 9" pitch. I don't know if those units apply down there when it comes to props, so that is 29.8cm by 22.9cm pitch. Basically it is first gear.... Sounds like your prop is as good as it gets. Not sure how much faster you expect to motor? The limitation is not the prop, but horsepower (lack of) and also a sailing boat (mono or multi) does not motor much faster than 7 knots at this length because of the aft shape of the hull. The stern gets sucked down at speed. A genuine power boat has 'buttock' line relatively flat to the waterline, which help support the weight of the boat and reduces the displacement wave the hull has to climb over to go faster. This is why it is so hard to get a good 'motor sailor' design... Quote Link to post Share on other sites
ScottiE 174 Posted March 10, 2015 Share Posted March 10, 2015 When ever I'm motoring I always feel like I should chock the motore so that it is negatively raked on the transom and chuck a heap of weight on the bow. From what you're saying Tim - it seems like that would be a bit pointless? Quote Link to post Share on other sites
paxfish 5 Posted March 10, 2015 Author Share Posted March 10, 2015 Thanks for your comments everybody. My intention with the original question was to figure out if a higher pitched prop would be proper, given that I have to replace the prop anyway. The general consensus is NO! Quote Link to post Share on other sites
Tim C 23 Posted March 11, 2015 Share Posted March 11, 2015 When ever I'm motoring I always feel like I should chock the motore so that it is negatively raked on the transom and chuck a heap of weight on the bow. From what you're saying Tim - it seems like that would be a bit pointless?I think it's best just to accept that you all have a likely top motoring speed of 6-7 knots, and don't try too hard to go faster! If you want to go fast go multihull sailing! (See I changed it!) Quote Link to post Share on other sites
ScottiE 174 Posted March 11, 2015 Share Posted March 11, 2015 cheers Tim - never a truer word spoken (though there are two words missing in the last part of your statement ; - "go" and "multis"!) Quote Link to post Share on other sites
ScottiE 174 Posted May 25, 2015 Share Posted May 25, 2015 does anyone know anything about the Hondas? Their BF20 wieghs and costs about the same as the yamie 9.9 high thrust. Quote Link to post Share on other sites
