Plastic Welding, Jabsco pump body -Archived Thread re-posted
rigger
Plastic Welding
Fusion
Posted: Wed Jan 21, 2009 3:39 pm Post subject: Plastic Welding
Who or where could I get the plastic part on that pump plastic welded,
Its a Jabsco pump body on a friends boat. They dont have that kind of spare part, just rebuild kits.
wheels
Posted: Wed Jan 21, 2009 3:44 pm
Whats the pump?? A Toilet pump?? That should have a pump body available. In fact any Jabsco pump should be able to have the body replaced.
Fusion
Posted: Wed Jan 21, 2009 3:53 pm
It is a diaphragm vacuum pump.
wheels
Posted: Wed Jan 21, 2009 3:58 pm
Oh and I assume it is that black plastic stuff. I am not sure than can be welded. I think it is a thermoset plastic. Once it has been heated and molded, it doesn't melt again. But i am not positive on that, so stand to be corrected. It could be possible to repair with a metalset type epoxy though.
I still find it hard to believe a body is not available as a spare part though.
Fusion
Posted: Wed Jan 21, 2009 4:03 pm
I agree. I think he has ordered a replacement but not in the country and they may want to use the shower?
wheels
Posted: Wed Jan 21, 2009 4:10 pm
Darn and I had one of those pump bodies too. I could have sent it up to you, but I am pretty sure I threw it out. I will check tomorrow just to be sure, but I am 99.9% sure it went in the rubbish.
Knot Me
Posted: Wed Jan 21, 2009 5:13 pm
Plastic Repair Company (or very similar name) in Glenfield valley (Archers road, I think). They do some stunning work on cars parts and assorted plastic stuff.
The owner is nearly a boatie as well. Put a mast on the launch of his and he would be
Don't know them but they have done a few bits for us and I've watch them in action. Rather impressive to see what they can do.
PaulR
Posted: Wed Jan 21, 2009 9:54 pm
Try also plastic bumper repairs for cars.
fng
Posted: Thu Jan 22, 2009 7:42 am
if its thermo plastic you could try pvc cement ( the stuff for plumbing pipes ) dab a bit on the pump body somwhere and if it mildly eats into it you have a winner . Or there's always super glue
PaulR
Posted: Thu Jan 22, 2009 8:17 am
If using super glue, I have then applied an external "LUMP" of glue from a hot glue gun and faired this over a crack to support the super glue in the actual crack / join. The extra bonding seemed to work well, as othertimes just super glue was no that successful.
Hope that helps too.
wheels
Posted: Thu Jan 22, 2009 9:27 pm
Sadly Pipe cement only works on PVC materials. Superglue can work, but is not perfect. But epoxy will work fine. Look for the specialised epoxy metal repair ones. Try a bearing sales or engineering supplies outlet and they should have small syringe type Locktite or similar name products. They glue the stuff very well.
