paxfish 5 Posted October 28, 2016 Share Posted October 28, 2016 So, after 6 vertical years, my mast is now down gracefully, and sitting on the pier for the winter. In general, it looks good. My shrouds and forestay terminate to a large shackle, and their eyes are tied around bronze thimbles. This has resulted in very little wear to the shackle. The bronze eyes are about worn out though. One is badly cracked as well. Can I re-tie the eye (Dyneema Dux) of the shrouds directly to the shackle without fear of abrasion? How do you guys handle this on your rotating rigs? Quote Link to post Share on other sites
MartinRF 53 Posted October 29, 2016 Share Posted October 29, 2016 Let me start with a disclaimer: I have no first-hand experience of synthetic standing rigging. My all-steel implementation is very similar but with three extra toggles to minimize fatigue inducing bending of the wires. To me the implementation shown in your photos looks really good. I would replace what is worn without changing anything. Others may have wiser advice... /Martin Quote Link to post Share on other sites
Ed 143 Posted October 29, 2016 Share Posted October 29, 2016 On a side note I would have a good look at that carbo block I assume is for the jib halyard. Depending on how you tension the halyard I would think the loads are getting very close to the max fit that type when new. For static high load applications I would look at using a low friction ring instead. Quote Link to post Share on other sites
MartinRF 53 Posted October 30, 2016 Share Posted October 30, 2016 Yeah, I thought about that block too. A ball bearing block for a static load does not make much sense to me. This study may interest you: http://hem.bredband.net/b262106/Boat/Blockfriction.pdf /Martin Quote Link to post Share on other sites
paxfish 5 Posted October 31, 2016 Author Share Posted October 31, 2016 Very good! Thank you gentlemen! Ed - I do have a ring that can be used there rather than the carbo. "Straight up the koozer!" Thanks for that bit of advice also - I did not realize that the Brummel might reduce line strength. Tell ya what though - That thing ain't moving! Without the Brummel, what length of tapered tail would I need? The same? P>S. A quick Google yields this article: http://www.chicagoyachtrigging.com/18-dyneema-break-test-final-bury-splice-vs-brummel-splice/?v=7516fd43adaa I think the author believes that while a bury splice has a higher breaking strength, both are rated higher than line strength.,.,,. Quote Link to post Share on other sites
paxfish 5 Posted November 1, 2016 Author Share Posted November 1, 2016 Gotcha - I'm guessing there is no way in hell I'm gonna get new thimbles installed without re-tying. I can get the old ones out without damage, I'm sure.... Quote Link to post Share on other sites
paxfish 5 Posted April 25, 2017 Author Share Posted April 25, 2017 Just an update. After much consultation in various quarters, and considering the good advice here, I replaced my shrouds with 8mm SK-75, and no thimble. The shroud diameter is overkill for sure, negating any weakness in the very secure Brummels I tied. I have deadmen on the side shrouds now, which are pretty sweet. After several day sails in winds to 17knots, the construction stretch is mostly gone now, and I'm liking the security of having new shrouds! As Always, thanks to all for your input.... Quote Link to post Share on other sites
ScottiE 174 Posted April 26, 2017 Share Posted April 26, 2017 Looks good - what's the diameter of the shackle crown? Would be interested to know KM's thought on whether it's a bit tight. Quote Link to post Share on other sites
paxfish 5 Posted April 27, 2017 Author Share Posted April 27, 2017 I believe the shackle crown is 18mm diameter. I hit it hard with polishing rouge and a wheel to get it to a mirror finish before I put it up. The line is Amsteel SK-75 Quote Link to post Share on other sites
