ab1974 1 Posted January 17, 2017 Share Posted January 17, 2017 We are looking to get the cabin top of our cat wrapped. The boat builder we have used to repaint the topsides has suggested we give the idea a miss as his experience is that the wrap fairly quickly deteriorates and cracks (in the Queensland sun). I appreciate there are different quality wraps on the market. It would work for us as to repaint the cabin top (paint in good condition but want to do something before I don't have any options left other than to repaint) as to repaint involves a fairly significant tenting or removal of the rig / shed hire. Also will allow us to go for a slightly different graphic look for the boat. Thoughts on wrapping generally / quality of wrapping products welcome. Quote Link to post Share on other sites
wheels 543 Posted January 17, 2017 Share Posted January 17, 2017 I don't know enough to comment on the wrap itself, although I doubt Queensland Sun is any worse than NZ Sun. But the one comment I can make, is that what is beneath still needs to be good quality for the wrap to adhere too. So if the surface is bad now, you are still going to need to sand it and prime it to create a good durable surface.We have a resident crew member that does this for a living, so you should get some great advice soon hopefully. Quote Link to post Share on other sites
Battleship 100 Posted January 17, 2017 Share Posted January 17, 2017 These Guys, http://vinylboatwrap.co.nz/ Looks like the good 3m stuff has a 7 year warranty. Quote Link to post Share on other sites
Dagwood 57 Posted January 17, 2017 Share Posted January 17, 2017 Might pay to double check that any warranty applies to horizontal surfaces. When I was selling the stuff (approx. 10+ years ago) the warranty was based on vertical applications. Quote Link to post Share on other sites
tuffyluffy 76 Posted January 17, 2017 Share Posted January 17, 2017 These Guys, http://vinylboatwrap.co.nz/ Looks like the good 3m stuff has a 7 year warranty. 7 years sounds pretty good depending on the fine print. As comparison, my white two-pot painted topsides are 7 years old now and have lost their gloss and are starting to look a little shabby. Quote Link to post Share on other sites
raz88 96 Posted January 17, 2017 Share Posted January 17, 2017 Friends have their hull wrapped, and while it was easy to apply and looks good (although as noted above the condition of what's underneath affects this), it's not as durable as paint and does get damaged reasonably easily. I would think if it were somewhere that you walk on it wouldn't last. Would also potentially be very slippery? Quote Link to post Share on other sites
ab1974 1 Posted January 17, 2017 Author Share Posted January 17, 2017 Thanks guys Paint is in good condition - though starting to dull and getting thin where cut and polished a few times. We wont typically walk where the wrap is - so hopefully slipperiness not an issue. The horizontal warranty comment is interesting - will have to check that. Quote Link to post Share on other sites
southernman 73 Posted August 4, 2019 Share Posted August 4, 2019 Does anyone have any updates on wrapping a hull? Considering it as an option instead of a repaint. Quote Link to post Share on other sites
Ex Machina 365 Posted August 4, 2019 Share Posted August 4, 2019 Copper coloured wrap . It was the applicators first go at doing a boat and it came up really good . Almost a year old and holding up well .sideways phone pics Quote Link to post Share on other sites
southernman 73 Posted August 4, 2019 Share Posted August 4, 2019 Looks good. I just like the idea of not polishing and minimal cleaning. No fading also. I was not considering doing a hand paint job, does not really compare with spraying. Quote Link to post Share on other sites
southernman 73 Posted August 4, 2019 Share Posted August 4, 2019 Thanks Mate, I will look into it some more regarding rolling. Good point about removal of the wrap, had not thought of that. Quote Link to post Share on other sites
mattm 98 Posted August 5, 2019 Share Posted August 5, 2019 My boat has a new professional roll / tip finish. The painter had just moved to a new shed, they got in trouble after the first boat they sprayed as the shed didn’t have the correct air filtration. My boat was out of the water with the mast out ready to go in the shed. Rather than wait, they roll and tipped, with sanding between each coat. Must have added a. Sh1t load of labour to it. Fortunately they had quoted and stuck to their original price. The outcome you wouldn’t know wasn’t sprayed, looks just the same. Don’t pick an option based on it being cheap would be my advise though. To hand paint and get a great finish, you need good rollers, good brushes, good paint, the right thinners and plenty of time. There’s no cutting corners. To do a good wrap, you need to do much of the same prep, just like paint, the wrap won’t be better or last longer than what ever is under it. I’ve seen a few boats get wrapped thinking it just solved their issue of poor hull condition. Didn’t work out so well. Quote Link to post Share on other sites
vic008 17 Posted August 5, 2019 Share Posted August 5, 2019 Slightly OT, but used graphics for name on topsides, so now when time to repaint do you peel them off or paint around them or what? Quote Link to post Share on other sites
Ex Machina 365 Posted August 5, 2019 Share Posted August 5, 2019 Paint over it then pick them out again with felt tip in colour of your choice Quote Link to post Share on other sites
Ex Machina 365 Posted August 5, 2019 Share Posted August 5, 2019 Na ...heat gun on low and a plastic scraper to peel them off . Once you get a corner lifted keep it warm with the gun and gently keep peeling . Should come off easily if it isn’t too old Quote Link to post Share on other sites
harrytom 642 Posted August 5, 2019 Share Posted August 5, 2019 From what I have seen with a few alloy fizz boats. the wrap looks nice when first fitted but over time anchor chips away at wrap or fender slips when berthing,a small tear arrives which lets a bit of moisture in and eventually have a black dot where wrap has punctured. Quote Link to post Share on other sites
southernman 73 Posted August 5, 2019 Share Posted August 5, 2019 Thanks good advice, looks like all systems have their pro's and con's. Quote Link to post Share on other sites
Abel Seaman 19 Posted August 5, 2019 Share Posted August 5, 2019 Rolling and tipping can definitely rival a spray job, you need to have good paint and the right amount of reducer plus technique. Years ago a mate of mine rolled a boat with interspray and it came up absolutely mint, and that was before the "brushable" paints were around. Its done a lot in europe in areas where spraying is verboten but you need a few practice runs and youtube instruction. You dont get anything for nothing, wraps may be perfect for you but dont kid yourself that it wont fade and it also needs to be replaced at the useby date unless you like spending your week with peeling of 2 inch bits Hmm, - reminds me of a stainless steel tank that was supplied to a project in australia. The stainless sheet was supplied with a wrap to protect the surface. The fabricators removed strips to weld the strakes together as is standard practice. The project suffered delays and delays and the tank sat outside in the weather. Finally it was installed and people started trying to remove the wrap. Too late it had stuck firmely and degraded. Never mind 2 inch strips, that would have been doable. Picture instead, confetti stuck on with superglue! Many have tried with many solvents and scrapers, but half the tank is still carrying immoveable plastic wrap! Quote Link to post Share on other sites
DrWatson 375 Posted August 5, 2019 Share Posted August 5, 2019 The wrap on my boat is very easily damaged last lift the straps damaged the edge in at least 2 places... Also, docks with gusty wind and strong currents are not my friend... Quote Link to post Share on other sites
