Gas bottles
80 replies to this topic
#1 Knot Me... maybe
Knot Me... maybe
  • 4,597 posts
Posted 01 March 2017 - 07:09 PM
Anyone know where I can get some 2kg gas bottles that can be used when lying on their side?
All I can find are ones that have to sit upright.
#2 ScottiE
ScottiE
  • 3,951 posts
  • LocationAuckland
Posted 01 March 2017 - 07:34 PM
It's not so much that the tank must be upright, it's that the valve must be at the top when in use. Presumably you could get someone to manufacture a tank to suit your needs?
Anthony
#3 native
native
    useless around the house
  • 3,019 posts
  • LocationThe Shore
Posted 01 March 2017 - 09:25 PM
There is a hire place on East Coast Road in Forest hill
When I look upon seamen, men of science and philosophers, man is the wisest of all beings; when I look upon priests and prophets nothing is as contemptible as man.
#4 Knot Me... maybe
Knot Me... maybe
  • 4,597 posts
Posted 02 March 2017 - 11:47 AM
Na, I'm told it's the pick up inside that varies. But I'll check on that valve thing, I haven't heard that before.
I can use std ones but due to the pick up I'll only be able to access about 1/2 their contents they say.
Our forklift has lay down bottles ..... and I as I wrote that I just had a idea who to ring.... DOH!!!
A fly by up Forrest Hill way in the morning is on the cards as well.
#5 ScottiE
ScottiE
  • 3,951 posts
  • LocationAuckland
Posted 02 March 2017 - 12:13 PM
I thought domestic bottles don't usually have a pick up - that's why they suggest a 20% vapour volume at the top.  But you are right - all you really need is a mini forklift bottle if such a thing exists!
Anthony
#6 erice
erice
  • 3,689 posts
Posted 02 March 2017 - 12:25 PM
CNG vs LPG
different things
different requirements?
if posts offend .. or even too hard
please "ignore" :thumbup:
http://crew.org.nz/f...ea=ignoredusers
#7 wheels
wheels
  • 16,534 posts
Posted 02 March 2017 - 03:41 PM
Nope, there is no pickup in them. Bog standard normal LPG cylinders that is.
The Fluid is pumped in under pressure, which keeps it liquid. LPG is at ruffly 150PSI. As the gas bleds off, the liquid turns to Gas at it's surface and replaces the gas that just went out the valve. If you tip a tank over and the liquid level reaches the valve, liquid LPG then runs out the Valve and into the Regulator, which is not designed to regulate liquid and will let some liquid through. As soon as the LPG is in the low pressure side of the pipe/hose, it boils, vaporises and expands instantly, raising the pressure in the outlet line which should normally have been regulated. It can even spit out liquid LPG at the jet.
The tanks on Forklifts I don't know about. They may have an internal pipe and I would imagine that if there is a marking of some kind that suggest one way up, then that would be the reason. But engines also have a totally different regulator design and while once again I don't know, the reg may be capable of handling liquid LPG.
#8 Knot Me... maybe
Knot Me... maybe
  • 4,597 posts
Posted 02 March 2017 - 03:50 PM
That's what I thought as well. But on asking On Gas who supply our gas bottles for here at work on the forklift and at home, we run off bottled gas, they agree with Wheels.
I sussed the forklift bottle to see this
Attached File  DSC_12671.JPG   148.43KB   0 downloads
Which shows a level when used horizontally and another if used vertically.
So I'm thinking there is no difference..... but I'll check a bit more just in case.
#9 jonathan
jonathan
  • 196 posts
Posted 02 March 2017 - 05:22 PM
search on trademe, there is a supplier of all sizes, does recon bottles with recent hydro
#10 wheels
wheels
  • 16,534 posts
Posted 03 March 2017 - 05:43 AM
The reason I know about the internals of the Bottle is because we recycle the Bottles to scrap. So I have undone a few valves and cut the tanks open.
  • 1
