Guest 000 Posted March 29, 2017 Share Posted March 29, 2017 What's the deal with mechanical gearboxes by which I mean the little lever actuated cone boxes typically found on yachts in the 30-35hp range? As far as I can see, the loading on the box is pretty constant as are the revs which only vary by a few hundred rpm's, yet almost everyone I know has had gearbox troubles at some time. In fact the ZF box used to be known as the 'dollar an hour gearbox.' It cost you a thousand bucks and was good for a thousand hours. They've gone up hugely in price recently so I suppose now they are the two dollars an hour box. Compare that with automotive gearboxes which are multi stage,operating under varying rpm and loading and I don't know anyone whose automotive box has failed. Are marine mechanical boxes just inherently unreliable? Quote Link to post Share on other sites
Island Time 1,234 Posted March 29, 2017 Share Posted March 29, 2017 I think they mostly suffer selection issues. This is often operator error - fwd - neutral - reverse or vice versa with no pause in neutral so the engine is doing too many revs when it engages, shock loading the cone clutch. It's not a clutch plate/pressure plate like a car, as that would be too big, and there is no manual clutch - all in the interest of miniaturisation. Selection issues have certainly been the main problem with my Volvo saildrive unit, although I'll admit it has about 10,000 hours!! Had 2 rebuilds in that time though... Quote Link to post Share on other sites
wheels 543 Posted March 29, 2017 Share Posted March 29, 2017 Yes it's the cone clutch that tends to be the problem. If you think about it, it's the clutch that goes on Car as well. The reason these boxes use such a means of engaging drive is because they don't have a clutch like a Car has that we need to engage. There are various designs across the manufacturers of course.The new owners of ZM have upgraded the design slightly. It will be interesting to see how this works out in hrs. It will likely be the reason for the price hike. It may well still be the dollar and hr box, by being $2/hr/2000hrs. Quote Link to post Share on other sites
Guest 000 Posted March 29, 2017 Share Posted March 29, 2017 I think they mostly suffer selection issues. Yes, and gearbox lever travel is also important - ensuring that the cockpit gear lever moves the box lever by the full amount. In this regard I wish the ahead gear would engage with a clunk like the astern gear does. We did have one occasion where one of us must have accidently bumped the gear lever out of full engagement. It was still propelling the boat but didn't do the box much good, I suspect. Quote Link to post Share on other sites
erice 732 Posted March 29, 2017 Share Posted March 29, 2017 you could put a little sticker, or paint a mark, at the full engagement position Quote Link to post Share on other sites
Guest 000 Posted March 29, 2017 Share Posted March 29, 2017 I was thinking maybe a bit of 3mm cord from the top of the gear lever to a plastic jam cleat. The lever is quite vulnerable to being bumped when we move around in the cockpit. Quote Link to post Share on other sites
Island Time 1,234 Posted March 29, 2017 Share Posted March 29, 2017 So the gear selector is not the throttle too? Quote Link to post Share on other sites
Guest 000 Posted March 29, 2017 Share Posted March 29, 2017 No, got an antiquated two-lever system. Quote Link to post Share on other sites
Island Time 1,234 Posted March 29, 2017 Share Posted March 29, 2017 Hmm unusual. I'd not be really happy tying the lever. Another issue in case of emergency. Quote Link to post Share on other sites
Farrari 4 Posted March 29, 2017 Share Posted March 29, 2017 Can you swap over the control from a two lever system to a single? I had this done on my Tracker. Quote Link to post Share on other sites
Guest 000 Posted March 30, 2017 Share Posted March 30, 2017 Yes, thought about it.. But that's a capex that would require approval from the Keeper of the Purse. Quote Link to post Share on other sites
