Guest shane Posted June 15, 2017 Share Posted June 15, 2017 Anyone have a cheep 15hp outboard engine for sale? Quote Link to post Share on other sites
Guest shane Posted June 15, 2017 Share Posted June 15, 2017 or anything 25hp 15hp 10hp 25 or 15 would be the best Quote Link to post Share on other sites
1paulg 17 Posted June 15, 2017 Share Posted June 15, 2017 I have a long shaft 2005 Johnson 15 hp regularly serviced that you could have for $1700 Quote Link to post Share on other sites
harrytom 642 Posted June 15, 2017 Share Posted June 15, 2017 If you looking using an outboard instead inboard I would consider a long shaft 15hp Yamaha or any well known brand,stay away from things like parsons etc and go new,2nd hand who knows what abuse it has had,new in most cases is not much more,charge system 4 stroke ,need a decent bracket that you can adjust easily. what is wrong with inboard as cost of o/b may fix inboard? Quote Link to post Share on other sites
wheels 543 Posted June 15, 2017 Share Posted June 15, 2017 Shane has no money, so no point in suggesting 1700 or something new. Shane is going to need a bargain basement price for something. The problem is Shane, you are likely to get something that is going to give more trouble than good and they are expensive things to get serviced.And can you simply hang the outboard on the Transom? or are you going to need some kind of mounting bracket? which happen to be expensive also. Then you have the cost of Petrol and two stroke oil and then you have the issue of it going stale of you don't use it much.You are also probably going to need to look for a long shaft outboard.Did you find out what is wrong with the Diesel engine? Quote Link to post Share on other sites
Black Panther 1,581 Posted June 15, 2017 Share Posted June 15, 2017 What boat id he sailing? Quote Link to post Share on other sites
harrytom 642 Posted June 16, 2017 Share Posted June 16, 2017 h28? Quote Link to post Share on other sites
erice 732 Posted June 16, 2017 Share Posted June 16, 2017 27' frank blom sinope schooner on tm in chch 2015 Quote Link to post Share on other sites
Black Panther 1,581 Posted June 16, 2017 Share Posted June 16, 2017 Lovely little boat. Id go for a pair of 16 ft oars. Probably row at around 4 kn in flat conditions Quote Link to post Share on other sites
Guest shane Posted July 1, 2017 Share Posted July 1, 2017 1PAULG can you please send me some photos off the engine you have for sale by my email shane.84801@gmail.com thank you Quote Link to post Share on other sites
Ed 143 Posted July 1, 2017 Share Posted July 1, 2017 Its cheap, but its in auckland, any good? http://www.trademe.c...-1361298020.htm Quote Link to post Share on other sites
wheels 543 Posted July 1, 2017 Share Posted July 1, 2017 Shane, forget the outboard idea. Hanging an outboard off the stern of your boat is not going to be easy. Put the money into fixing the engine. You have not yet said if you have had someone take a look at it for you.AND PLEASE REPLY to our messages here. It is so confusing to us all when we don't hear from you, you say one thing and then next we hear you are doing something different.Another possible job to for you, if you are still in Waikawa. Go see Aaron at Oddies. He was down two staff, but has had one new guy start in the last few weeks, but may still have another position available. Could also be worth popping you head into Burnsco as well.Oh and also go and see the local Boat Painting place at the Marina as well. In fact, just go poke your head into every business there and ask. You may get lots of no's, but don't take that personally. If there is not a position, then Businesses will say no, it's just a fact of life. But Business Owners like those that take the opportunity to look and ask. 2 Quote Link to post Share on other sites
