Cleaning Squabs
Hey All, Any one here know how to clean squabs, mine just seem to be constantly damp and need to get rid of any salt in the foam. So far I think using warm water to flush them and leaving them on the tramp to drain/dry. Ideas welcome. Cheers, Dan
Yep that's about it. Salt will absorb the moisture right out of the air. So if they ever got wet with Salt water once, you will have ongoing problems till they are washed and dried.
On larger cruising boats where they have the luxury of room, a rule is often made that you change out of salt wet clothes out in a "wet area" and then come inside and not to wear your boat shoes inside. Once you get Salt inside and especially on the carpet, it is a nightmare to keep dry. And you don't often have the luxury of a dehumidifier running when you are at sea.
"er indoors"isnt aware of this so............ light detergent and water, lay squab on clean concrete, soak with hose , on with detergent etc then pogo and shuffle and any other step you can think of work it all in, then tons of hose while still boogeying and finally........ cram the fucker into the gentle annie and do the final spin thing, you'll be surprised just how idiot/ abuse proof fisher and paykel made em.......cool to medium warm afternoon and quality rum help naturally...... done it 3 times so far
err remove the covers first and wash seperate
No need for warm water or detergent if you're only getting salt out.
Just keep rinsing them until you can't taste the salt in the water that drains through.
I rinsed mine with the sitting on an outdoor table (good gaps for the water to drain through). Covers and all, seeing as the zips were too corroded to get the covers off.
The roof deck is the roofing material layer between the primary structural components and either insulative layers or weatherproofing layers in a typical roof system. Usually the roof deck acts as a unifying structural diaphragm by tying all the structural components together.
Decking Timber
Are you on drugs or is it me? :D What are you talking about? :eh: The relationship between your topic and cleaning boats squabs is.... :?: :?: :?:
Due to a slight issue with the forward hatch last Saturday I had to clean and dry some squabs. It's easy.
Chuck them in the ute, take them home and say to the Wa 'Here clean these' :thumbup:
Easy peasy.
Sorry to bring your lovely dream to an end but the sun is up already and you need to put some clothes on and get to work pronto. :wave:
Oh have you got one of those machines too. Better than anything F&P have ever designed. I just have to drop the dirty clothes ont he floor and they eventually turn up in the draw all washed ironed and folded. Had mine 22yrs now and still going strong, although a few cosmetic blemishes here and there now, but hey, what wouldn't after 22yrs of hard use. Best $50 bucks I ever spent, even though at the time I did yell "how much??..but...but that's like....two trips up the Ski field!!"
