Tricky Inflatable Repair
Leak under join to hull
18 replies to this topic
#1 Clipper
Clipper
  • 3,711 posts
  • LocationAuckland
Posted 15 November 2017 - 10:25 AM
I have a zodiac 2.6m with a fibreglass bottom.  There is a slow leak from under the fabric of join of the tube to the hull.
I have the correct patches and glue etc, but dont think that will do any good, as patching the end of the join will just result in the air leaking past.  Its a slow leak, so I tried unsuccessfully to jam some sika in there.
Does anyone have any bright ideas on how to fix?
White stuff (sika) in second photo is where air is escaping.
#2 jonathan
jonathan
  • 200 posts
Posted 15 November 2017 - 10:43 AM
I think the existing seam has to be removed with heat,  leak patched then re glue the seam.
Can be done at home but probably better for a pro job if the rib is in great condition otherwise.
#3 Clipper
Clipper
  • 3,711 posts
  • LocationAuckland
Posted 15 November 2017 - 11:12 AM
Bugger.  Anyone got any suggestion on who might be able to do it?  Is in otherwise good condition, so dont want to stuff it up
#4 Dambo
Dambo
  • 538 posts
  • LocationAuckland
Posted 15 November 2017 - 12:22 PM
https://www.wilcomar...tServicing.html
#5 Knot Me... maybe
Knot Me... maybe
  • 5,520 posts
Posted 15 November 2017 - 12:26 PM
https://www.seafarerinflatables.co.nz/
#6 Fish
Fish
  • 3,039 posts
Posted 15 November 2017 - 02:09 PM
Sailors corner have a product, you put it inside the tubes, to seal leaks such as this. Like a wash around internal solution. I haven't used it, it's not cheap. But if it's only a slow leak it may be effective.
#7 jonathan
jonathan
  • 200 posts
Posted 17 November 2017 - 07:27 AM
wow if you try that product let us know how it works...
#8 native
native
    useless around the house
  • 3,488 posts
  • LocationThe Shore
Posted 19 November 2017 - 05:30 PM
Wouldnt use that shmoo, same category tire repair in a can. Might be too late but if you could get a heat gun and very gently heat n’ peel those seams you might be able to syringe some two pot contact into it.
#9 jonathan
jonathan
  • 200 posts
Posted 19 November 2017 - 06:23 PM
thats the correct way to fix this.....   i reckon a pro job be about 200
#10 harrytom
harrytom
  • 1,555 posts
  • LocationAuckland
Posted 19 November 2017 - 06:52 PM
used one those tyre pando things in a pelican tubed dinghy once,total failure due to no heat unlike a car tyre,pump it in and drive,
