Tazzy Devil 18 Posted December 23, 2017 Share Posted December 23, 2017 I’ve got a Vulcan 7 and was wanting to add a transom Mount fishfinder transducer That can plug into the Sonar port. It says it can be done in the manual but I can’t seem to find any info online as to what Transducer will fit/work, was thinking a lowrance or Simrad might but the ATL guys say no. I don’t want anything fancy, just a transom Mount on a suction cup that can be deployed whilst fishing. Depth and speed com from the through-hull transducers already. Anyone have any ideas? Anyone done this already? Quote Link to post Share on other sites
Island Time 1,227 Posted December 24, 2017 Share Posted December 24, 2017 The lowrance and simrad ones are exactly the same. What Max depth are you looking for? Quote Link to post Share on other sites
Island Time 1,227 Posted December 24, 2017 Share Posted December 24, 2017 Here is the offical note on the dealers spec page: Integrated CHIRP / DownScan / ForwardScan. Single 9 Pin Xsonic connector. Connection to any external sounder module is not supported. So I’d recommend, unless fishing deep If fishing deep, then perhaps XSONIC AIRMAR TM185 HW TM185HW Wide Beam, CHIRP, $1560 rrp incl. Sorry I’m away til 19 Jan, could not supply one myself until then. Quote Link to post Share on other sites
Winter 42 Posted December 24, 2017 Share Posted December 24, 2017 I have the same question, but for the Zeus2, which doesn't have a sonar port. I already have speed/depth/temp. Quote Link to post Share on other sites
Island Time 1,227 Posted December 24, 2017 Share Posted December 24, 2017 Then winter, you need to add a sonar hub to your Ethernet system. RRP $1039 incl. this gives you the same options as above, plus the blue connection transducers - totalscan, structure scan etc. Quote Link to post Share on other sites
Tazzy Devil 18 Posted December 24, 2017 Author Share Posted December 24, 2017 Thanks heaps.... will be in touch early feb for a tdx May yet go through hull Quote Link to post Share on other sites
