wheels 543 Posted January 23, 2018 Share Posted January 23, 2018 If no luck it will pay to check the engine compression with the correct tester. Standard compression testers will not do the job. It's called a leakdown tester. Not easy to do on the boat though. You need an air supply. Quote Link to post Share on other sites
vic008 17 Posted January 23, 2018 Author Share Posted January 23, 2018 All good. Thanks for suggestions. The old what did you do that it wasnt happy with? Hose I replaced to inj pump was 1/4" should be 5/8. Anyway put bigger hose on and she went. Restricted fiel supply? or kink? Definitely fuel squirt out of pipe. Quote Link to post Share on other sites
rmiker 15 Posted January 23, 2018 Share Posted January 23, 2018 All good. Thanks for suggestions. The old what did you do that it wasnt happy with? Hose I replaced to inj pump was 1/4" should be 5/8. Anyway put bigger hose on and she went. Restricted fiel supply? or kink? Definitely fuel squirt out of pipe. Yea Good work back.. I had a similar one where I was getting fuel as well: turned out to be a partially blocked fuel filter.. Quote Link to post Share on other sites
Myjane 40 Posted February 10, 2018 Share Posted February 10, 2018 Stick to the basic problem fuel line let air in , replace , bleed hole system , filters , injectors, and lines and should go Quote Link to post Share on other sites
