antifoul wax paper
I'm about to antifoul and want to avoid the big buildup of mussels on the bottom of the keel.
I've heard that after you lift and paint the bottom of the keel (where it rests on the cradle), you can lower the boat onto wax paper so that the antifoul doesn't stick to the steel cradle when you launch. Ideally you would hold the boat in the air until the antifoul is thoroughly dry but at $140 per hour that's a bit expensive an impractical.
Does anyone know what sort of wax paper is best and where to buy it?
Depending on the yard where you're doing the antifouling it's worth asking whether they will hang you in the travel lift overnight and re launch you in the morning? Last I did mine I was able to organise to do that the evening before I was due to go back in and it definitely didn't cost $140 an hour :)
