Priscilla II 376 Posted February 20, 2018 Share Posted February 20, 2018 Engine room ventilation that is. Looking for ideas to provide adequate fresh air delivery to my engine compartment. Quote Link to post Share on other sites
BMW56 12 Posted February 20, 2018 Share Posted February 20, 2018 If you blow the engine room will be under slight pressure and fume laden air could be forced into the cabin via various fortuitous paths if there isn’t sufficient ventilation. On that basis it’s probably better to suck, then you can direct any fumes and odours safety outside. Quote Link to post Share on other sites
wheels 543 Posted February 20, 2018 Share Posted February 20, 2018 Depends on what you are trying to accomplish. If you want a ventilation fan as a safety device to remove fumes/vapors only and it only gets used for that purpose, then you suck. You never want negative air pressure in the engine compartment. If you are wanting to provide extra air for the engine and aid cooling in the engine compartment and the fan will run often, then you blow. Quote Link to post Share on other sites
Island Time 1,211 Posted February 20, 2018 Share Posted February 20, 2018 What wheels said, diesels hate insufficient air, the engine room should never have negative pressure. Quote Link to post Share on other sites
Priscilla II 376 Posted February 20, 2018 Author Share Posted February 20, 2018 Is this style of blower rated for continuous operation and how noisy are they. If I am blowing fresh air into the compartment to feed the engine etc do I also need to extract as well. Quote Link to post Share on other sites
BNG 44 Posted February 20, 2018 Share Posted February 20, 2018 Is this style of blower rated for continuous operation and how noisy are they. If I am blowing fresh air into the compartment to feed the engine etc do I also need to extract as well. Just like your sails - Flow is Go Bro. Yes - at the minimum needs to be well vented. If the ventilation ok it shouldnt need extraction as well as blower. Quote Link to post Share on other sites
Fish 0 Posted February 20, 2018 Share Posted February 20, 2018 Its not so much the blower style but the motor rating for continuous operation. I have fitted a blower to my engine box. I started with a cheapie axial blower from Burnsco, it was noisier than the engine... General Marine Services do a range of blowers, Giavani, from Italy, centrifugal (like the one in your picture) rated for continuous operation, and have a rated noise output. I can confirm that they are quiet, and good blowers. Most blowers don't have a rated noise output, mainly cause they are very noisy. Make sure you are sitting down when you get the price though. Quote Link to post Share on other sites
Fish 0 Posted February 20, 2018 Share Posted February 20, 2018 Sorry I spelt the company name wrong. this is the type of blower I've got, and is well suited to yacht engine ventilation: https://www.gianneschi.info/en/product/524 The specification sheet has the noise outputs in dBa. It's on the website somewhere, or General Marine would be able to help you out. These are good blowers, are designed for continuous operation in the marine environment, you will find the pricing substantially different to a plastic Chinese blower though. Quote Link to post Share on other sites
Black Panther 1,568 Posted February 20, 2018 Share Posted February 20, 2018 Suck don't blow, that's just a figure of speech and likely to make your ears pop. Quote Link to post Share on other sites
Priscilla II 376 Posted February 21, 2018 Author Share Posted February 21, 2018 The largest sucker of air in the engine compartment is the fresh air intake manifold. How about just a old fashioned stand pipe with a 75mm flexi hose directly attached and do away with the air filter. Heat exchanger should be sufficient in keeping things cool so more interested in adequate engine air supply. Have sound proofed where I can and given the correct required volume of air is quite a bit I am not happy with just nooks and crannies and gaps to provide. 1 Quote Link to post Share on other sites
Island Time 1,211 Posted February 21, 2018 Share Posted February 21, 2018 Indeed, there should be proper air intake ducts. Air filter - do you mean the engine air filter? I'd not do away with that! I know some boats don't have them, but that's dumb. A filter will help provide the engine a long life. I know many have crap filters, and IMO an upgrade from a foam filter to a proper washable filter like a k&n is worthwhile. A good idea is an air duct that can be shut off in case of fire... A really good engine room has intake ducts with salt scrubbers, shut off hatches, and is quite airtight otherwise... Quote Link to post Share on other sites
Priscilla II 376 Posted February 21, 2018 Author Share Posted February 21, 2018 A really good engine room has intake ducts with salt scrubbers, shut off hatches, and is quite airtight otherwise... And there I was thinking that the end was in sight for my engine replacement project.... Quote Link to post Share on other sites
wheels 543 Posted February 21, 2018 Share Posted February 21, 2018 A really good engine room has intake ducts with salt scrubbers, shut off hatches, and is quite airtight otherwise... And there I was thinking that the end was in sight for my engine replacement project.... But have you got an engine room or an engine box? Big difference. An engine room can allow for a very decent and dangerous fire and having the ability of starving it of oxygen is beneficial to putting the fire out. The largest sucker of air in the engine compartment is the fresh air intake manifold. How about just a old fashioned stand pipe with a 75mm flexi hose directly attached and do away with the air filter. Heat exchanger should be sufficient in keeping things cool so more interested in adequate engine air supply. Have sound proofed where I can and given the correct required volume of air is quite a bit I am not happy with just nooks and crannies and gaps to provide. I am not sure what you are actually trying to achieve. Are you preempting you might have a problem with heat? or do you actually have a problem with heat or not enough air for the engine intake? Quote Link to post Share on other sites
Chloe 7 Posted February 21, 2018 Share Posted February 21, 2018 The way I see it is that most boat engines are sucking in warm/hot air all the time. with an external Air intake to the engine with filter your engine will get colder air. However that is easier on launchers than yachts. Quote Link to post Share on other sites
Priscilla II 376 Posted February 21, 2018 Author Share Posted February 21, 2018 Wheels, the old diesel just sat tucked away in the rear end of the yacht with little thought given to fresh air intake. I have upgraded the diesel to a Beta 3 cylinder and now looking for a simple solution to provide fresh air to the intake manifold without having to resort to a electrical blower. Heat is manage by the exchanger so I am going to head for a ducted intake with a stand pipe tucked up in the back of the cockpit Surprisingly most of the yachts I have seen have no dedicated fresh air intake system and a few have blowers to just cool the alternator. Quote Link to post Share on other sites
Fish 0 Posted February 21, 2018 Share Posted February 21, 2018 The Beta installation manual has a good section on this. Effectively you just have a hole in the engine box, and to manage noise you make a baffle. Most yacht engines manage fine by being open underneath to the bilges, the draw in sufficient cool air from there. The engine box itself suppresses the noise. You will be surprise how effective and appropriately designed baffle is for suppressing noise break-out while letting air in. Just out of interest, how does your new Beta go on the noise front, what size is it, and what did you pull out? I have been looking closely into re-powering with a Beta. Unfortunately non of the engine suppliers provide dBa levels for their engines. Most claim there engine is the best / most balanced / has the best injector pump so therefore is the quietest. With all of the EC conformance testing, power analysis etc, it is beyond me that they can't provide a standard dBa rating. Quote Link to post Share on other sites
wheels 543 Posted February 21, 2018 Share Posted February 21, 2018 Thanks for the clarification. The engine sucking hot air certainly does mean you lose Hp. But like most sailboats, you rarely use all the Hp available anyway. The Engine can be a big help in sucking in the Hot air in the box and allowing colder air to enter the box. Make sure you have a vent somewhere in the Box wall to replace the air the engine is sucking up. The heat comes off the Engine block and exhaust manifold, so the heat exchanger is not helpful in reducing the heat in the box. Quote Link to post Share on other sites
Priscilla II 376 Posted February 21, 2018 Author Share Posted February 21, 2018 Fish, I replaced my aged 17hp 2 cylinder marinized Kubota with a 25hp Kubota based Beta. Quite a task which included a new larger fuel tank, complete engine bed, exhaust system, electrical wiring, prop and battery management etc.... Basically I have turned my old log of wood sailboat into a launch and realistically the total speed gain achieved from old to new is about 1.5 extra knots when motoring to wind and tide. Got sick and tired of beating home up the harbour at 3 or so knots which in my view has more tidal flow due to the harbour being constantly stolen by POAL. In fifteen years of ownership the old Kubota received one birthday and never let us down, however now we have a smooth modern quieter? more powerful donk and its red as well. I use diggers onsite frequently that have similar Kubota power plants and they run and sound like the ducks nuts . The only weakness in the Beta conversion is the aluminium heat exchanger casing so keeping the pencil anode refreshed is important. I do not like Volvos not only because they are green. Yanmar was my first choice but price and layout saw me go Beta. I have sound insulated only the removable engine compartment front/companion steps and sound wise we are happy, I do like to be able hear a engine run. Quote Link to post Share on other sites
Fogg 427 Posted March 13, 2018 Share Posted March 13, 2018 My production boat has extractor fan fitted as standard in the engine room. The original Jabsco unit recently died so I replaced it with a identical TMC 4” in-line blower but after 3hrs use the fan blade flew off. A few days later Burnsco swapped it another TMC (on the advice that TMC is normally good kit) but exactly the same thing happened to the new unit after 30 mins. So I returned it for a refund and will never buy another item if TMC kit again. So stick with Jabsco is my advice although as someone else said they are all quite noisy. Quote Link to post Share on other sites
Priscilla II 376 Posted March 13, 2018 Author Share Posted March 13, 2018 Interested in knowing where your engine sources it’s fresh air intake from. Quote Link to post Share on other sites
