Leaking injector
Recently the boat has become quite smelly after a period of motoring. I think I've narrowed it down to a leak on the high pressure side at the injector - see photo.
Just wondering if its a good idea to snug it up or do i need a pro? If tightening it up is the the upper or lower nuts?
All thoughts appreciated. ..
The upper nut. The one with the line going directly into it. Give it a nip up. The lower one is the return line and has no pressure.
Then give the nuts a wire brush and spray a little protective paint around them to stop rust destroying the threads.
  • Upvote 2
