Chewing Gum 17 Posted July 21, 2018 Share Posted July 21, 2018 Tips for polishing st st stanchions, pushpit etc How to passivate ? Quote Link to post Share on other sites
Vorpal Blade 89 Posted July 21, 2018 Share Posted July 21, 2018 Autosol is the polish of choice for the professional polishers on the big $$ boats. Quote Link to post Share on other sites
Steve Pope 243 Posted July 21, 2018 Share Posted July 21, 2018 Passivate "any new welding" with Avesta Pickling paste, be careful, nasty stuff!! Quote Link to post Share on other sites
Dtwo 157 Posted July 22, 2018 Share Posted July 22, 2018 Electro polish Quote Link to post Share on other sites
marinheiro 352 Posted July 22, 2018 Share Posted July 22, 2018 Emergel if there is any rust staining, then Autosol, and maybe a wax polish to finish off Quote Link to post Share on other sites
BMW56 12 Posted July 24, 2018 Share Posted July 24, 2018 Once you have it nicely polished a wipe down with some olive oil will slow down any future tarnishing or staining. You can't use any coatings that keep oxygen away from the surface of the stainless, but the olive oil provides an oxygen permeable barrier to any salt and keeps the finish nice. It only needs a very thin film, but be careful not to make anything slippery that shouldn't be. Quote Link to post Share on other sites
Chewing Gum 17 Posted July 25, 2018 Author Share Posted July 25, 2018 Thanks guys - some good tips. I am not that fussy either but ongoing problem with one foot of pushpit that had wet rope resting on it for some time. Ever since it is badly rusty looking which can be removed with polishing but soon comes back so really needs passivating. Will try some of the remedies suggested, possibly the milder ones before trying the Hydrofluoric acid which I was aware of and also aware of its nasty properties. Quote Link to post Share on other sites
bigal.nz 59 Posted July 27, 2018 Share Posted July 27, 2018 Ive used autosol a few times, but it all depends on what the job is. If your going from mill scale to glamour then its working through the grades, flap wheels, buffs, pastes etc... But autosol is what Id use on an existing setup I have been using autosol, but there is one metal bar in particular that might need something more aggressive before finishing with Autosol - which product do you suggest before the autosol? Quote Link to post Share on other sites
BMW56 12 Posted July 27, 2018 Share Posted July 27, 2018 You can get flap discs for an angle grinder that clean up stainless quite nicely. They come in various grades so you can start coarse and finish fine. They aren’t as aggressive as you might think. Bunnings should have them, but my local Mitre 10 doesn’t. Otherwise wet and dry sandpaper. Then you can use a kitchen pot pad to finish off. NOT a Steelo pad - never use steel wool on stainless as it will start it rusting. The synthetic pads like Scotch Bright work well but you will need to use some elbow grease. Then you can buff up using Autosol. If you are doing the work on the boat make sure you clean up any dust if you use a flap disc or sand, otherwise it will very quickly rust and stain paintwork. Quote Link to post Share on other sites
chariot 243 Posted July 28, 2018 Share Posted July 28, 2018 Have used Braso and a soft cloth. Works well. 1 Quote Link to post Share on other sites
