Island Time 1,230 Posted July 4, 2019 Share Posted July 4, 2019 Ok, so ballpark $ in NZ? Quote Link to post Share on other sites
wheels 543 Posted July 4, 2019 Share Posted July 4, 2019 I missed the beginning of this thread and now the Vids are no longer available. What's all this about? Quote Link to post Share on other sites
Island Time 1,230 Posted July 4, 2019 Share Posted July 4, 2019 Check here wheels https://www.integrelmarine.com Quote Link to post Share on other sites
waikiore 398 Posted July 4, 2019 Share Posted July 4, 2019 The agent Sopac has stock, high $20,000 area. My question apart from having to buy it and lay in the big 48V battery pack is how much load on the crank? All modern engines have definite limits to PTO loading and side loading via the multirib belt . Also if this thing is mounted on bracketry off the engine -as it should be to move together how much extra weight on the engine mounts? Quote Link to post Share on other sites
wheels 543 Posted July 5, 2019 Share Posted July 5, 2019 This thing is more for the above average boat. The minimum bank size (and it is stressed as minimum) is 10Kwhr. That's a fair chunk of battery bank for a starter. The unit is aimed at Boats with high power demands, like say Charter Boats that are using AirC, Washing Machines, Dishwashers etc etc. Which you have to then question why they would not be using a dedicated Genset and providing mains voltage direct, rather than charge a large Battery bank at 48V, then convert that via a DC to DC charger to 12 or 24V to run the normal DC gear, then convert back to Mains via an inverter. So what am I missing here, especially as it is Nigel Calder. He's not silly. Why such a complex system that is kind of huge in ability and huge in size of battery banks, but seemingly aimed at being run by the smaller limited power engines. Quote Link to post Share on other sites
Jon 360 Posted July 6, 2019 Share Posted July 6, 2019 Interesting option If I was building a new 45’ plus boat I’d consider it quite seriously I went seperate genset so I had two independent power supplies Would be very realistic option in a Cat where you could have a duel system possibly and then have the backup of two generators powering one system ? Then not need a genset Quote Link to post Share on other sites
