Solar panel doesn’t appear to be charging.
#1
Posted 23 October 2018 - 04:21 PM
Another question from me - I have a solar panel that runs through a controller to the battery. It was working fine after installation earlier this year, but now it’s not. Today it was showing on the controller as the panel producing between 10 - 12volt, but no amps going into the battery. A volt metre confirmed the voltage - but I can’t figure out why it isn’t charging the battery.
#2
Posted 23 October 2018 - 04:47 PM
#3
Posted 23 October 2018 - 04:52 PM
10-12 volts wont charge the battery. Matt will probably chime in with a more detailed answer but if it was me I would disconnect the panel from the controller and check the voltage there to eliminate the controller as a possible cause. I Would expect more voltage than that.
Theodore Roosevelt
#4
Posted 23 October 2018 - 04:53 PM
if the panel is 10-12 v, and the controller is mppt, then the panel is shaded, has bad connections, or has failed. Take the wires off the controller - open circuit voltage should be over 19v.
#5
Posted 23 October 2018 - 04:58 PM
Edited by carpenter29, 23 October 2018 - 04:59 PM.
#6
Posted 23 October 2018 - 05:24 PM
#7
Posted 23 October 2018 - 05:44 PM
yep
#8
Posted 23 October 2018 - 05:47 PM
IT not all panels have an open circuit voltage higher than 19V.
#9
Posted 23 October 2018 - 05:50 PM
True, but the vast majority do, and 10-12v disconnected is bad
#10
Posted 23 October 2018 - 07:31 PM
Is it a flexible panel?
Had three fail in 2 years, gone to glass/alloy.
