Hot water tank (calorifier) removal
17 replies to this topic
#1 Neil
Neil
  • 264 posts
  • LocationWaimauku, Auckland
Posted 05 November 2018 - 11:35 AM
For reasons I might discuss in another thread I have to remove the hot water tank (calorifier) from our Farr1220. On the tank there are 4 inlets/outlets as follows:
Potable Water (the water to be heated):
  • Fresh (cold) water in
  • Fresh (hot) water out
Engine Water (the water doing the heating):
  • Engine water in
  • Engine water out
The first two are easy when it comes to disconnecting. For the first the freshwater tanks will be shut off before disconnecting for the second Ill lose some water into the bilge that is sitting in the pipes between the tank and the hot water taps but that should not be much.
For the second two, Im a little more cautious. The water from the engine comes from the fresh water cooling circuit on our VP2003T. See attached photo for the two connections on the engine that lead down to the hot water tank.
I do not want to disconnect the pipes on the tank and end up draining all the coolant out of the engine (the hot water tank is lower than the engine header tank). Should I be disconnecting at the engine end first? Note the two outlets on the engine are also slightly lower than the level in the coolant header tank. Once disconnected and caps put on the inlet/outlet on the engine will the engine still be ok to run?
Also, I need to think about the reinstall later and making sure there are no air lock issues.
Thoughts?
#2 Island Time
Island Time
  • Administrators
  • 6,342 posts
Posted 05 November 2018 - 12:04 PM
Neil, you will lose some coolant. Unavoidable. It will drop to the heat exchanger level. No problem, except the mess. Just top it up when refitting. Above the coolant tube on the exhaust riser is a brass plug. Open that when refilling to remove the airlock, or better yet take it out and put it where the barb to the header tank hose is - swap them around to avoid airlocks in future.
#3 Neil
Neil
  • 264 posts
Posted 07 November 2018 - 06:33 AM
Tank out with surprisingly little mess :-)
Now I'm setting up a test in my garage to determine the source of our problem. There is a leak from the tank which I thought might have been the relief valve but now think the tank itself is f**ked.
Any advice on buying a new tank/calorifier?
#4 Priscilla II
Priscilla II
  • 1,116 posts
Posted 07 November 2018 - 03:41 PM
Neil if you think it is shagged why not remove the outer casing and check the copper inner cylinder.
Maybe a repairable leaking fitting rather than a case of aged related corrosion.
Looks like you have no electric element so contact https://www.sigmashe...water-cylinder
#5 Neil
Neil
  • 264 posts
Posted 08 November 2018 - 09:03 AM
Yesterday I did just that. The leak seems to be coming from the tank itself in the area of the white stuff (which I presume is some form of corrosion). The comedy moment was when I realised - too late - that the insulation inside the lining was thousands of bean bag beans. It took some time to get control of the garage back from the tsunami of little white balls!
Some pics and you can just about see the leak in the video:
Priscilla, thanks for the link, I'll contact those guys and see what advice they can give, not much hope for the tank though I think.
#6 Island Time
Island Time
  • Administrators
  • 6,342 posts
Posted 08 November 2018 - 04:35 PM
Yep, its stuffed. What type of, and what % of corrosion inhibitor was in the cooling system? That's failed due to corrosion...
#7 Island Time
Island Time
  • Administrators
  • 6,342 posts
Posted 08 November 2018 - 04:37 PM
General Marine services (GMS) do new ones, or maybe https://www.hotwater...ml#.W-O9UtIzbcc
no doubt there are others...
#8 Neil
Neil
  • 264 posts
Posted 08 November 2018 - 04:58 PM
The engine coolant will have whatever they put in at the last service. However, I think the problem is on the fresh/potable water side that goes to the taps in the boat which will be just pure water from the marina tap.
#9 Neil
Neil
  • 264 posts
Posted 08 November 2018 - 04:59 PM
 Yep, GMS is one of the many places on my list to go visit this week.
#10 Island Time
Island Time
  • Administrators
  • 6,342 posts
Posted 08 November 2018 - 05:12 PM
Yep, could be Neil, copper tanks don't last forever!
