Sail Rock 28 Posted December 16, 2018 Share Posted December 16, 2018 I am considering fitting a wind vane self steering unit to my boat (Chico 30) that has a transom hung rudder. It would need to be installed off centre so as to be clear of the rudder and I am wondering how well the proprietary systems like Hydrovane operate off centre when the boat is heeling. Also interested in whatever tips/opinions/advice people might have on the various systems available, e.g. Hydrovane, Monitor, Fleming, etc. Alternatively does anyone out there have a rudder trim tab type of system that I could take a look at? Quote Link to post Share on other sites
Steve Pope 243 Posted December 16, 2018 Share Posted December 16, 2018 Most of the modern designs of windvane work well when fitted off centre. Trim tab self steering works well. It can be by attaching a Trim Tab to your existing rudder, for which a transom hung rudder lends itself. The further back from the existing rudder you place the TT the more powerful it will be. Or by attaching a secondary rudder with a trim tab attached, This is suitable for anything other than transom hung rudders. I have a trim tab system that is similar to the "Auto-helm" design made by Scanmar in the us. (google) It is a cable operated system. I have put the vane above the radar arch and have actuating cables that work the TT. There are yachts (mostly older) using this system, mostly out of America if you look amongst the visiting offshore fleet I'm sure there will be examples to study. It is as near to bullet proof of any I have come accross. Of interest is the yachts in the current Golden Globe race that have had difficulties with some makes of modern SS set ups. Quote Link to post Share on other sites
southernman 73 Posted December 16, 2018 Share Posted December 16, 2018 I have a Hydrovane installed on my yacht and it's offset, it works perfectly. My only thoughts would be that it's a lot of weight to have on the stern of a small boat. Key points I've learnt from using a Hydrovane are: - balance of the yacht is important i.e. not overpowered. - Make sure the mounts are ROCK solid, there is a LOT of force involved on this thing in a seaway and high winds - Make sure you fully test all functionality in all winds before you have to rely on it. I'm lucky that I also have a autohelm - The Hydrovane is a better option in my opinion due to the fact it runs totally independent of the rudder and also for Cat 1 can act as compliance for a secondary steering device for the yacht if you lost your rudder. - They are bloody expensive don't go cheap on the installation - Get a good setup for your control lines, ideally to the cockpit companionway. Makes it easy to adjust or gype the boat while on the winches etc. Otherwise you have to trim, then move back and adjust the boat trim - Have a very good method to lock off the helm and ability to adjust it to a slight angle if required for boat trim. If you want photos let me know. Quote Link to post Share on other sites
Sail Rock 28 Posted December 17, 2018 Author Share Posted December 17, 2018 Thanks for the tips guys. SM - yes, some photos would be helpful if not too much trouble for you to upload. Quote Link to post Share on other sites
Priscilla II 392 Posted December 17, 2018 Share Posted December 17, 2018 “They are bloody expensive don't go cheap on the installation” SR if you are doing coastal why not save some roubles and go Autohelm or similar. Power demands can be met by solar which offers more options for other use. Self steering weighs quite a bit and generally speaking is of more practical use for offshore passages. Quote Link to post Share on other sites
wild violet 38 Posted December 17, 2018 Share Posted December 17, 2018 Hydrovane far to big for a chico,i have a late model fleming lovely light unit,saying that any boat with a stern hung rudder can have a small light trim tab fitted,which is as simple as it gets.And is basicly bulletproof. Quote Link to post Share on other sites
southernman 73 Posted December 17, 2018 Share Posted December 17, 2018 Yip can post photo. Hydrovane far too big for a chico - Nope, plenty of 30-33 ft boats with Hydrovanes on them. The weight of most Hydrovanes is around 35 kg's. The Fleming also can't be used as a back up rudder right? I've found offshore sailing that the windvane is the best bet and that's on a fairly modern cruiser also. Sure the autohelm is great also but solar alone on a 30 ft boat won't keep up with the demands of the autohelm especially in robust conditions and if you fancy a cold beer also. Not unless you plan on having an ugly boat with lots of solar panels mounted all over the joint If you are doing local stuff then yes run with the autohelm. The main issue on the chico is mounting a decent autohelm, can be done but takes up cockpit room. I'd go with the windvane if you are heading offshore. The installation of a decent autohelm adds up real fast, keep that in mind also. Saying that a Hydrovane is not a cheap investment either. Just my 2 cents, have owned a chico 30, great boat. Quote Link to post Share on other sites
Priscilla II 392 Posted December 17, 2018 Share Posted December 17, 2018 “The installation of a decent autohelm adds up real fast,” Pretty much plug and play for a boat that size. Quote Link to post Share on other sites
southernman 73 Posted December 17, 2018 Share Posted December 17, 2018 “The installation of a decent autohelm adds up real fast,” Pretty much plug and play for a boat that size. Doubt it if you compare apples with apples you would likely need: - Mounting Bracket - Compass - Hydraulic Ram - Controller - Run the cables - Power Supply - Upgraded battery capacity - Upgraded charging capacity Hmmmmm not much change out of 5k i'd suggest. Not sure I'd be trusting a cockpit based plug and play autohelm in anything more than a cruise up the Coast. Each to their own I guess. Quote Link to post Share on other sites
Island Time 1,235 Posted December 17, 2018 Share Posted December 17, 2018 5k is about right for a complete AP system (drive, AP computer, controller etc) suitable up to about 35 ft, unless your happy with a tiller pilot , from $850-1500 Fitting would be additional. But, modern aps are much more flexible than a wind vane, with proper wind steering, Nav, route following and alarm systems. If your boat is heavy on the helm, the AP will suck power. Fix the trim, then not so much. 1 Quote Link to post Share on other sites
Priscilla II 392 Posted December 17, 2018 Share Posted December 17, 2018 Doubt it if you compare apples with apples you would likely need: - Mounting Bracket - Compass - Hydraulic Ram - Controller - Run the cables - Power Supply - Upgraded battery capacity - Upgraded charging capacity Hmmmmm not much change out of 5k i'd suggest. Not sure I'd be trusting a cockpit based plug and play autohelm in anything more than a cruise up the Coast. Each to their own I guess. Crikey it’s a Chico 30 not a 40 footer. Quote Link to post Share on other sites
Steve Pope 243 Posted December 17, 2018 Share Posted December 17, 2018 every plus has a minus, also known as unintended consequences. Quote Link to post Share on other sites
Guest 000 Posted December 17, 2018 Share Posted December 17, 2018 A big thumbs up for windvane self steering. A good example of the KISS principle. I built mine which means I gained a good understanding of the concepts involved in windvane trim tab self steering gear. It also means that I can repair it. Anywhere. Quote Link to post Share on other sites
wild violet 38 Posted December 18, 2018 Share Posted December 18, 2018 Used my fleming in 50 knots this year no worrys thats what they are for,Used another fleming on a delivery down wind storm jib only old heavy steel boat got knocked down and main hatch blown in by a wave vane just kept on going,would have been dangerous to be outside hand steering.Were surfing at up to 14 knots. Not sure how an autopilot would have handled it only use mine for motoring Quote Link to post Share on other sites
Island Time 1,235 Posted December 18, 2018 Share Posted December 18, 2018 properly spec'd AP's will steer in anything... B&G H5000 AP Quote Link to post Share on other sites
wild violet 38 Posted December 18, 2018 Share Posted December 18, 2018 Would cost more than my yacnt thougn eh Quote Link to post Share on other sites
Island Time 1,235 Posted December 18, 2018 Share Posted December 18, 2018 That can be a problem ! Quote Link to post Share on other sites
Priscilla II 392 Posted December 18, 2018 Share Posted December 18, 2018 Crikey now the Chico 30 has transmogrified into a Open 65. Sailrock what are your sailing intentions. Quote Link to post Share on other sites
Yourmomm 2 Posted December 18, 2018 Share Posted December 18, 2018 I've got an atoms hanging off the back of my 25ft boat: it had a much bigger windvane before this one (german wind pilot pacific light), and i understand it worked fine. There's a video on YouTube of a previous owner having this one working, on this boat, too...I'm going to try to get her in a mooring at westhaven this weekend (to remove the bowsprit), if you want to come and have a look at it then. If I've got time, I'll be taking the vane off, as well, so I can remachine a rusted through part and get it working again... Quote Link to post Share on other sites
Black Panther 1,584 Posted December 18, 2018 Share Posted December 18, 2018 I have sailed across the tasman on a chico ( the boat had just won the single handed trans tasman) had a brilliant system with custom centerline vane direct to a trim tab on the out board rudder. Worked brilliantly. Cheap to make. Quote Link to post Share on other sites
