Chewing Gum 17 Posted January 15, 2019 Share Posted January 15, 2019 Filled up 200 litres from empty there in October - definitely no water. Quote Link to post Share on other sites
harrytom 640 Posted January 15, 2019 Share Posted January 15, 2019 Talking to my supervisor today regarding water in fuel,yes there is a bit in fuel but should not be detectable,if it is then the owners of the tank are not turning it off soon enough(trip switch failure)30000lt tank last 3000 lts tank should switch off as this is the water table,in general tanks get sucked clean every 2 yrs. Quote Link to post Share on other sites
Crazyhorse 47 Posted January 15, 2019 Share Posted January 15, 2019 I did tanker work for a while (hookers) and there is a standard to do with water suspension. That is the amount of unseparated water in the fuel where it remains in suspension. I've said this before, you wont see the water at the pump. It takes months if not years to separate which is why boats and some stationary engines get water in the tank (some through condensation too) as opposed to truck and car tanks which are getting filled regularly. Diesel will freeze at a lower temperature than ether type fuels partly due to water content. I believe JET-A1 even has water in it but at a very low level. I have the parts now but yet to install a circulating filtration pump and filters water separator which hopefully will keep what water there is in the tank in suspension and whatever condensation that has separated gets removed....fingers crossed. Quote Link to post Share on other sites
Addem 94 Posted January 22, 2019 Share Posted January 22, 2019 I just cleaned a heap of gunk out of our tank. I’ve got 20l of contaminated diesel. How do you dispose of it? We’re based in Tauranga. Quote Link to post Share on other sites
Jon 355 Posted January 22, 2019 Share Posted January 22, 2019 Not sure if your ment to or knot but last time I did it I dumped it into the waste oil recycling container at the marina. Diesel is oil after all isn’t it. Quote Link to post Share on other sites
Addem 94 Posted January 23, 2019 Share Posted January 23, 2019 I think that that’s a no-no. There is a big sign beside the drum making it quite clear. I recall the recycler saying the biggest risk to them is the amount of petrol/diesel/thinners and other volatile fluids that get put in their drums. Apparently they heat the oil to distill the water out before the next stages of recycling (whatever that is). But thinking about that I might call them to see if they want it. Quote Link to post Share on other sites
Fish 0 Posted January 23, 2019 Share Posted January 23, 2019 I would think it is far better to put waste diesel in the used oil collection thanks than anything else you can think of. The options are: 1) down the stormwater drain 2) down the loo 3) pour onto some ground somewhere Either way you are contaminating the environment with hydrocarbons, even down the loo (it all ends up in the sea, wastewater treatment doesn't remove hydrocarbons, it removes your poos). Unless you can incinerate it somehow, but considering its got water and gunk in it, I doubt that would be effective. Putting it in a plastic bottle and out with the trash will just cause leachate at the landfill, i.e. contaminate the environment some more. The oil recycling is an industrial process designed to cope with removing impurities from hydrocarbons... Quote Link to post Share on other sites
Jon 355 Posted January 23, 2019 Share Posted January 23, 2019 The crowd that pump your tank out when you pickup the wrong hose at the fuel seller (it’s self service so no service station any more) maybe you can take it to them ? They must recycle it or something from fish’s list Quote Link to post Share on other sites
Addem 94 Posted January 24, 2019 Share Posted January 24, 2019 I think that that’s a no-no. There is a big sign beside the drum making it quite clear. I recall the recycler saying the biggest risk to them is the amount of petrol/diesel/thinners and other volatile fluids that get put in their drums. Apparently they heat the oil to distill the water out before the next stages of recycling (whatever that is). But thinking about that I might call them to see if they want it. I took it to the Oil recycler (Waste Mangement in Tauranga) and they reluctantly took it for me. I’m not sure if they would have if it was a smaller amount. Mine was 22 liters mostly diesel (I.e. not too much water). Quote Link to post Share on other sites
