Laptop power options
28 replies to this topic
#11 Ed
Ed
  • 564 posts
Posted 12 January 2019 - 09:08 AM
There are some laptops that can be charged through their USB C port as an option
#12 lateral
lateral
  • 943 posts
  • Locationauckland
Posted 12 January 2019 - 09:33 AM
My toughbook CF52 sayes 8A on the plate! So only use it occasionally.
Plotter & iPad is enough.
#13 Crazyhorse
Crazyhorse
  • 879 posts
Posted 12 January 2019 - 09:47 AM
These could be the answer? Getting your hands on one in NZ would be the problem.
https://liliputing.c...ng-in-2019.html
#14 Crazyhorse
Crazyhorse
  • 879 posts
Posted 12 January 2019 - 09:51 AM
Ouch!!! ($$$$)
#15 Beccara
Beccara
  • 499 posts
  • LocationWhangarei
Posted 12 January 2019 - 10:51 AM
https://www.pbtech.c...er--with-USB-Fa
DC-DC is best, This would do the job for most laptops. If you want to ensure higher reliability select a laptop with a processor like an intel I3 or just go for the panasonic toughbook
https://www.trademe....9b3b0d78333bc77
https://www.trademe....c7a4746d7fd6139
#16 lateral
lateral
  • 943 posts
  • Locationauckland
Posted 12 January 2019 - 11:39 AM
Yep on the step up converter.
I5's are still 5A
Half the price on ebay.
#17 bigal.nz
bigal.nz
  • 217 posts
  • LocationNew Zealand
Posted 12 January 2019 - 11:46 AM
I would stay away from anything celeron based - be slow as s**t.
Core i5 minimum with SSD - a platter disk wont survive the knocks and SSD is flippin cheap now anyway.
There are so many laptops around now with screens between 12-14 inches which I find a good size for boating.
In terms of power I dont know about Toughbooks, but I would be surprised if the charging circuitry is much different to a normal laptop which is 19v normally taking about 2-3 Amps if also charging (maybe startup surge up to 4A.
PB Tech is good and if your in Auckland NZ Laptops (Mt Wellington) have some good deals on A grade ex lease gear.
Edited by bigal.nz, 12 January 2019 - 11:46 AM.
#18 idlerboat
idlerboat
  • 1,710 posts
  • LocationVictoria, Australia
Posted 12 January 2019 - 01:42 PM
As per IT.
Dc to DC converter.
12 (or so) in and usually a choice of output voltages.
Some have a multi position switch and others have little plug in do hickys (that look like blade fuses) to select the appropriate output voltage.
They are not expensive and are quite reliable. Mine is currently outputting 19 volts.
There is only two substances..stuff and glue...and even glue is made of stuff,,
quote."MD"
#19 bazzathemammoth
bazzathemammoth
  • 189 posts
Posted 12 January 2019 - 05:53 PM
I bought an old hp laptop with ssd for $125 on tm. Got a 12v charger from work and it uses a suprisingly small amount of power. The main thing for whatever you get is to make sure it has a SSD, as this means more reliable and less power draw.
#20 Myjane
Myjane
  • 727 posts
Posted 13 January 2019 - 10:02 AM
My laptop in the day ran straight of the 12 volt no probs even tho it was rated for max volts 17 , 12 volt try it
