Laptop power options
28 replies to this topic
#21 mcp
mcp
  • 200 posts
Posted 13 January 2019 - 10:21 AM
My laptop in the day ran straight of the 12 volt no probs even tho it was rated for max volts 17 , 12 volt try it
It will likely run because laptops and computers internally regulate to 12v nominal.   However, I doubt it would charge the battery properly, even though the batteries will be 3 paralleled lithium cells [either Lithium-Ion or lithium polymer] and they have a charged voltage of 12.6v [4.2 v per cell] the charging circuit would require 16 + volts to supply decent current for the absorption phase of charging.
#22 Crazyhorse
Crazyhorse
  • 879 posts
Posted 13 January 2019 - 02:20 PM
It might boot OK but they run on 19v for a reason. Drop the voltage and the wattage stays the same so you are drawing more current. Not a good idea. Your laptop will cook if you don't give it additional cooling then that defeats the idea?
#23 Zozza
Zozza
  • 806 posts
Posted 14 January 2019 - 07:01 AM
Would this work?
http://www.bixnet.co...c120uc28m1.html
Attached File  adapter.PNG   256.03KB   0 downloads
#24 Crazyhorse
Crazyhorse
  • 879 posts
Posted 14 January 2019 - 07:59 AM
Thats it. Just check that the plug is going to fit your laptop, theres lots of different sizes.
#25 Island Time
Island Time
  • Administrators
  • 7,083 posts
Posted 14 January 2019 - 08:33 AM
Then cut the stupid lighter socket plug off, and put on a decent one, or wire directly. Don’t forget the fuse!
Never heard of that brand though. You might be better with an established brand - one you’ve heard of, or belkin...
#26 Crazyhorse
Crazyhorse
  • 879 posts
Posted 14 January 2019 - 08:45 AM
Ours has lasted years (jaycar?) A "projecta". Probably can't get them anymore.
#27 Sabre
Sabre
  • 1,138 posts
Posted 14 January 2019 - 09:22 AM
Yep that looks the go. Still haven’t made it to PB tech yet, too busy fitting my home made removable prod amongst other things. Too many projects not enough time but getting there.
I will definitely be hard wiring it.. those Ciggy plugs seem to wriggle loose evertime you look away!
My laptop has an 11.1v battery so does that mean it will run on 11.1v but needs more to charge? The ac adaptor is 16v.
#28 Island Time
Island Time
  • Administrators
  • 7,083 posts
Posted 14 January 2019 - 10:20 AM
It needs the 16v to charge properly
#29 Crazyhorse
Crazyhorse
  • 879 posts
Posted 14 January 2019 - 05:23 PM
And dangerous! IT is dead right, if the connection is not good they will heat up something shocking. You won't notice it until the cabin starts filling with smoke. Small loads no problem, but run about 3 amps and up with a bad connection and they soon get very hot. Those white plugs in that photo are what we use "fuseable link" plugs. Simple, reliable and easy to fit. Not sure why they are called that as there isn't a fuse in them?
