What is this for?
21 replies to this topic
#11 Island Time
Island Time
  • Administrators
  • 7,082 posts
Posted 22 January 2019 - 09:58 PM
Spinnakers are still useful unless you have a real high performance boat. Still best for sailing deep. Asymmetrics for reaching, so no need for a jockey pole.
I have both.
#12 idlerboat
idlerboat
  • 1,710 posts
  • LocationVictoria, Australia
Posted 23 January 2019 - 12:28 AM
For cruisers..
   The best use for a whisker pole is to pole out your genoa when running down wind and just off..., to stop it doing the "stingray"
...and if you dont know what that means..just have a look at the front section of a stingrays "wing" when it moves through the water  :-) .
Try it ..you will love it.
ps..beautiful versions were made for just that job in either spruce or bamboo in the past. super light, and just strong enough so that they would break if to much strain came on the rig while the skipper may or may not have been having a quick nap.....
There is only two substances..stuff and glue...and even glue is made of stuff,,
quote."MD"
#13 philstar
philstar
  • 637 posts
Posted 23 January 2019 - 03:53 AM
Yup it's a whisker pole. Used to keep the brace off the side stay when shy reaching with a kite up.
Also very useful for poling out a genoa.
Hang onto it.
#14 John B
John B
  • 2,655 posts
  • LocationAkl
Posted 23 January 2019 - 04:07 AM
Er, how does a stubby little jockey pole that just makes past the caps work as a Genoa or jib whiskey pole? Poling a Genoa needs nearly as much length as a kite pole, more like say 100% of the J is good, so you can leave it in its mast fitting and the beak on the deck by the stem.
With my old 70s dip pole gybe and jockey pole boat, I just use the kite pole and vector the length using the pole track, its 'kin wonderful....roll up the jib with the pole still on, set it anything from full out to 3 or 4 ft of sail to control speed. Cruising is about arriving when you want to, often that means slowing down.
  • 1
#15 Knot Me... maybe
Knot Me... maybe
  • 6,115 posts
Posted 23 January 2019 - 07:39 AM
The whisker is only to give better angles on the brace when tight reaching. That better angle makes it easier to keep the pole off the forstay which then increases safety and reliability.  It's a geometry improving device.
They are usually too short for poling anything out.
  • 1
#16 mcp
mcp
  • 200 posts
Posted 26 January 2019 - 10:11 AM
I have both.
I don't have a real high performance boat its an early 80's IOR special from South Africa.     I have an old furling 140% Genoa that I plan to replace with a 100 - 120% depending on who is giving me the advice and either a Symmetric or an Asymmetric.  Currently, I sail wing on wing downwind or just take an as best angle as I can.  I could still somewhat pole out an Asymmetric for downwind?
#17 Island Time
Island Time
  • Administrators
  • 7,082 posts
Posted 26 January 2019 - 11:10 AM
Yep. Wing and wing works, and can be reefed if you have roller furling. Asymmetrics still best for reaching. If I had only one, it'd be the A2.
#18 Frank
Frank
  • 269 posts
Posted 26 January 2019 - 02:43 PM
You mentioned cruising until you run out of money well you could get a head start by buying both a spinnaker and an A2, they are quite expensive sails plus you then have to store both. I would go for some sort of asymmetric and ditch the whisker pole, with that and the genoa you have plenty of options.
#19 Martin Wright
Martin Wright
    Newbie
  • New Members
  • Pip
  • 1 posts
Posted 08 April 2019 - 10:37 PM
Cool! I have just joined this site because I've got one of these weird poles on my Cavalier 32.
So, just to be clear, the normal end is clipped to the brass loop (about a meter up the mast) and the other end sticks out at right angles so the windward spinnaker sheet can run through it when the spinnaker pole is pointing forward. Have a got that right? Also, will the whisker pole need to be supported with top, forward and aft lines?
#20 eruptn
eruptn
  • 348 posts
  • LocationRotorua
Posted 13 April 2019 - 11:16 AM
These show the jocky pole been used with a spinaker guy ..... tight reaching (images stollen of net)
Ross 650 Farr 940
