muzled 140 Posted February 5, 2019 Share Posted February 5, 2019 Does anyone know where you can buy 1 piece dorades with a flexible base? I can only find the new version which has no base as part of the actual dorade but has a plastic insert (with the base) which goes up into the dorade (bit hard to see on this link but there are two parts - https://fostersshipchandlery.co.nz/products/homer-low-profile-flexi-cowl-vents) I can't get my bronze (screw on) fitting over the bulge in the new version. ta Quote Link to post Share on other sites
Kevin McCready 83 Posted February 5, 2019 Share Posted February 5, 2019 link broken. no bracket on the end. good luck. https://fostersshipchandlery.co.nz/products/homer-low-profile-flexi-cowl-vents I got water through my dorades the other day ploughing through waves. I should have swivilled them backwards. Quote Link to post Share on other sites
Priscilla II 377 Posted February 5, 2019 Share Posted February 5, 2019 Give me the width of the dorade mouth as they came in two sizes and I will scratch around tomorrow and see if I have one spare. Quote Link to post Share on other sites
muzled 140 Posted February 5, 2019 Author Share Posted February 5, 2019 link broken. no bracket on the end. good luck. https://fostersshipchandlery.co.nz/products/homer-low-profile-flexi-cowl-vents I got water through my dorades the other day ploughing through waves. I should have swivilled them backwards. Thanks KMC but that's the one I've got that I can't get on. Give me the width of the dorade mouth as they came in two sizes and I will scratch around tomorrow and see if I have one spare. Priscilla, it's got a 100mm base. Happy to trade home brew if you have one lying around. Quote Link to post Share on other sites
Priscilla II 377 Posted February 5, 2019 Share Posted February 5, 2019 Found this. 100mm. If you wipe with TMK Amazing Haste and spray with can of all in one paint and primer spray can from Wairua Paint Centre will look like new. Quote Link to post Share on other sites
muzled 140 Posted February 6, 2019 Author Share Posted February 6, 2019 Found this. 100mm. If you wipe with TMK Amazing Haste and spray with can of all in one paint and primer spray can from Wairua Paint Centre will look like new. Cheers Priscilla, will send a pm. Quote Link to post Share on other sites
