Fogg 427 Posted March 7, 2019 Share Posted March 7, 2019 Reading all of the above - do you guys get my point about the complexities of 12v being far greater than AC! Quote Link to post Share on other sites
Crazyhorse 47 Posted March 7, 2019 Share Posted March 7, 2019 Reading all of the above - do you guys get my point about the complexities of 12v being far greater than AC! NO? Quote Link to post Share on other sites
Black Panther 1,581 Posted March 7, 2019 Author Share Posted March 7, 2019 Glass over ply. Switch was an automatic relay. Quote Link to post Share on other sites
Crazyhorse 47 Posted March 7, 2019 Share Posted March 7, 2019 Different. 12V dc is infinitely safer and less complex. But I agree on that it could lead to false complacency and fire. AC has added bonus of 3ph. eg People were getting shocks off the showers at a camp.Only 50hz tingle sort. Couldnt figure out as water pipes were solidly earthed. Even taking a lead back to switchboard earth peg. Only way we could fix it was balancing the loads on all 3ph's. 415V AC makes me notch up safety consciousness. Only ever deal with if a sparky won't get out of bed. So BP is your boat steel/ferro? That switch that is fried, was that to turn fields off manually? Remember the old Pye TV sets? Lightly run your fingers on the rabbit ear antenna and there is a very slight tingle. Even though you are not earthed, the fact that it's LIVE,yes they had energised chassis, moving the fingers was enough to change the phase shift to create an exceptionally small voltage potential. It was the norm then to have phase as the common. Quite safe unless you connect yourself the the earth side of a 3 pin socket! Quote Link to post Share on other sites
bazzathemammoth 37 Posted March 11, 2019 Share Posted March 11, 2019 Different. 12V dc is infinitely safer and less complex. But I agree on that it could lead to false complacency and fire. AC has added bonus of 3ph. eg People were getting shocks off the showers at a camp.Only 50hz tingle sort. Couldnt figure out as water pipes were solidly earthed. Even taking a lead back to switchboard earth peg. Only way we could fix it was balancing the loads on all 3ph's. 415V AC makes me notch up safety consciousness. Only ever deal with if a sparky won't get out of bed. So BP is your boat steel/ferro? That switch that is fried, was that to turn fields off manually? Quote Link to post Share on other sites
bazzathemammoth 37 Posted March 11, 2019 Share Posted March 11, 2019 Did you get the sparky to check your main neutral connection? If he didnt, dont use him again and find someone else to have a look at it. It sounds like there is a dodgy neutral to me. Believe it or not, the main earth peg does bugger all in most installations. Quote Link to post Share on other sites
bazzathemammoth 37 Posted March 11, 2019 Share Posted March 11, 2019 Yea. Redistributing the loads would have cured the symptom but not the cause. I hope it was sorted cuz a dodgy neutral can kill. Quote Link to post Share on other sites
Island Time 1,230 Posted March 11, 2019 Share Posted March 11, 2019 Agreed Baz, sounds dodgy AF!! Quote Link to post Share on other sites
Island Time 1,230 Posted March 11, 2019 Share Posted March 11, 2019 Its interesting how different people can have radically different responses to electrical shocks. 1 Quote Link to post Share on other sites
