Do I want brass or bronze?
as above, naval bronze for wet salt water use, if at all possible
stainless steel, brass, bronze are all alloys
some modern versions of all 3 alloys have been developed for marine use and should be fine, if you can find them
but just buying/using the cheapest stuff that looks 'right' can work out badly if it wasn't developed for 'marine use'
Aluminium makes brass stronger and more corrosion-resistant.
Aluminium also causes a highly beneficial hard layer of aluminium oxide (Al2O3) to be formed on the surface that is thin, transparent and self-healing.
Tin has a similar effect and finds its use especially in seawater applications (naval brasses).
Combinations of iron, aluminium, silicon and manganese make brass wear and tear resistant.[9]
https://en.wikipedia.org/wiki/Brass
