Hobie 16 refresh
10 replies to this topic
#1 Hurts
Hurts
  • 466 posts
Posted 28 April 2019 - 01:23 PM
I bought a somewhat clapped out but still sail-able Hobie 16 (70's, 80's vintage) about 5 years ago for $1500. I initially wanted it for it's rig and sails for a Tri project but have moved on from that particular idea.  I have been leaving it on the beach at Pauanui, mast up, between Labour day and Easter each year and sail on it with the kids on the estuary and have slowly fallen in love with it's speed, simplicity, toughness and general retro awesome-ness.  It's perfect for the estuary as it can carry lots of kids and there are shoals and reefs everywhere which makes a centreboard a PITA.
However it's still clapped out (has got worse generally) and some asshole undid it's tie down to a tree at some stage and it got blown around in a storm and had some tree roots poke through the side of it's hulls (which I temporarily repaired).  I've bought it back to Auckland for a birthday - possibly a major one.
The hulls are basically screwed (soft, patched, leaking - designed in the 60's) - While I have developed a respect/love for the 60's hulls things have moved on design wise. I'm thinking of making some new ones but to a more modern symmetrical design with a skeg- i'e like the Hobie getaway or Nacra 570. I've built a farrier so I know my way around glass and foam building but I'm wondering if there are some hull plans I can acquire/buy? There are crap loads of old H16's around and going cheap... Surely someone has thought of this before?
I'm not concerned about resale value, class racing (though I would like to do the Matakana raid one year).  It's just for mucking about and to give me something to amuse myself in the workshop for the long winter months.
  • 1
#2 Puff
Puff
  • Marine Forums Only
  • 3,931 posts
Posted 28 April 2019 - 05:45 PM
There’s a fleet of more than half a dozen at Whitianga that race regularly. When you get it back come over for a blast. Some launch at flaxmill bay which saves a few km getting here
"Never attribute to malice that which is adequately explained by stupidity"
#3 erice
erice
  • 4,373 posts
Posted 28 April 2019 - 07:17 PM
the whole hobie16 things is a bit like a volkswagon beetle
pretty much everything is done differently and it's probably better to fix things than try to drastically replace them
1st up would be to remove any slop in the tramp hull sockets
https://www.youtube....h?v=q1-6JhsiOcg
then fix the soft spots by injecting epoxy
https://www.youtube....e 16 soft spots
get the rudders locking down easier + kicking back better with new cams
https://www.youtube....h?v=7jfn8f93XiQ
imho the hobie traveller is also horrendous, esp. the 80's version cast in to the rear beam
nothing to stop you riveting on a harken track and replacing the jib cleats
the australians discovered they pointed better if the mast was raked waaay back
without dagger boards this moved the CofE back to where the deep rudders can help prevent sideslip upwind
for 80s boats the way to rake the mast back beyond the last hole in the forestay plate, was simply to shackle another on in series
the americans liked it so much that 90s hobie16s came with a longer forestay
raking the mast also helps tack that horribly stiff battened jib past the mast halyards when the air is to light to blow it through
the key to sailing them fast is to ALWAYS keep your weight where it should be
forward + inboard in light air...difficult with the sloping tramp
aft, outboard and on the wire in heavy.....carpet tiles on the tramp frame is good non-slip
get on the wire as soon as needed and get over any fear of pitchpoling
when on the wire be ready to do your "peterpan" kick as soon as the bows go down
there's no time for any recovery, just kick + fly around the side-stays as the boat upends
seal the top of the mast to help prevent turtling and if you are tempted to sail it solo off beaches make sure to have a tested righting bag system to get it back up
if you wanted to build hulls for the tramp frame/rig etc.
the nacra 5.2 has about the same rig and sail plan and i could give you most the measurements in a couple of months when am back with mine or you could take measurements off Phil's 5.5 in auckland
or you could overbuild some old Acat hulls from plans, or scale down some tornado plans etc
if you still had the farrier plans some scaled or shortened floats would be ideal......if you do make floats some daggers or swinging centreboards, as used on the hobie 18, nacra 580? etc would greatly improve pointing and still allow safe runs into the beach....tho half the reason hobie can run into the beach is due to their deep V banana hull design and solid 50mm? keelsons?
and if you still wanted better after that
you could keep an eye out for the occasional old nacra or prindle on tm
life is short
live it!
without fear or prejudice
#4 southernman
southernman
  • 469 posts
  • Locationnelson
Posted 28 April 2019 - 08:46 PM
I used to race these a fair bit, don't anymore.  There is a guy on the North Shore Dave Tuke dave.mcglashan@hughesandtuke.co.nz who used to sell parts second hand and often had old hulls around after he had butchered boats.  You could contact him and see if he had a set around in good condition, probably a lot less then building a new set!!
#5 Hurts
Hurts
  • 466 posts
Posted 28 April 2019 - 09:02 PM
Thanks guys - Eric the tramp platform etc seems in reasonable condition but the hulls probably need more than just an epoxy injection- whoever sold it to me seems to have heard about the mast rake thing cos the current rake is incredible- it’s still pretty rubbish upwind. I quite fancy new hulls. the NACRA 5 is also a skeg keel but the 5.2 is a centreboard job. I’ve had a good look at a modern cat and can probably copy ones lines if required but I was wondering if someone had already done it. Is a swing centreboard with a slot etc actually better than a skeg? Marginally better I suspect but lots more to break? I really like the simplicity of not having boards - and enjoy hitting the beach at 15 knots...
I’m a bit Leary of the trapeze- if I’m doing mods I’ll probaby add some racks - it’s more appropriate for men of our years :-).
#6 Hurts
Hurts
  • 466 posts
Posted 28 April 2019 - 09:08 PM
Ok thanks I might try him - I’m not actually too worried about the cost in money or time in building some new hulls - I’d just like to ensure they are an appropriate design and superior to the old ones.
#7 erice
erice
  • 4,373 posts
Posted 28 April 2019 - 09:31 PM
the trapeze isn't as bad as it looks
but i guess could be hard work in choppy gusty conditions
this looks interesting
http://forums.sailin...amaran-14-18ft/
https://farevela.net...-ispira-classe/
or how about a 120% paper tiger?
life is short
live it!
#8 RushMan
RushMan
  • 852 posts
Posted 29 April 2019 - 10:17 AM
A skeg helps upwind but centre boards are better but if you plan on running it up the beach at speed the Hobie 16 is perfect!
The Hobie 17 has kick up centre boards and hiking racks. Also has a trapeze for the kids to play on.
#9 madyottie
madyottie
    Strike 3. Woods Strike 18 Trimaran
  • 911 posts
  • LocationDeepest Darkest Waikato
Posted 29 April 2019 - 01:11 PM
Richard Woods has a design called the Quattro 16, which probably ticks all your boxes. Designed for ply I think, it's what my tri was designed around, or vice-versa.
3mm ply is no match for 110kg size 11 boots! Anyone know how to fix my foredeck?
#10 Hurts
Hurts
  • 466 posts
Posted 29 April 2019 - 03:24 PM
Yes - that's close to the sort of thing I was after thanks - I do want to reuse all the functional Hobie bits and don't want to build from ply... the lines are certainly more modern than the Hobie but still quite dated compared to modern A's or F16's... There are plans for a "Blade F16" - which looks lovely but the tortchered ply method
http://www.thebeachc...g2_itemId=11955
looks horrendous compared to building in foam strips...  it's a hard road to find the perfect design - I guess I really want a slightly smaller Nacra 570 hulls...
