Battery Monitors
59 replies to this topic
#1 bigal.nz
bigal.nz
  • 159 posts
  • LocationNew Zealand
Posted 28 April 2019 - 09:33 PM
Hi All,
Part of my winter projects is to get my head around a few more of the electrical systems on the boat.
I have two displays that I think are both battery monitors:
https://photos.app.g...muP8oZgV7AnAXp8
Why would I have two, or have I missed something, is the Balmar one providing some sort of information about the output from the alternator that the Xantrex isn't?
Cheers
Al
#2 wheels
wheels
  • 16,716 posts
Posted 29 April 2019 - 06:13 AM
Yes, the Balmar is controlling the ALT and the Xantrex the Charger. The Xantrex should be the one set up primary monitor of the Battery banks.
The Link systems have long been considered the most sophisticated monitoring systems available (providing the have been programmed properly) and all other makes copied the features.
The two separate monitors will be giving access to the parameters of the charging units, so you do need both.
#3 bigal.nz
bigal.nz
  • 159 posts
Posted 29 April 2019 - 07:40 AM
So the Balmar controls the Alternator output (through charging regulator?) and displays information about Battery health?
The Xantrex controls ??? and displays information about battery health? (The same battery information as the Balmar display?)
To complete the picture the boat used to also have shore power/inverter chager but this was 100v and has been removed.
#4 wheels
wheels
  • 16,716 posts
Posted 29 April 2019 - 08:04 AM
Arrr, righty, the link20 would have controlled the shorepower charger. Sorry, I didn't realise the charger was removed.
You could remove the Link if you want, as it is doing mostly what the Balmar is as in reporting Battery state of charge.
Or you could buy a Xantrex charger that accepts the Link as a control, or the Heart Interface charger that was thew original charger the Link was first designed for. But they are expensive and may not warrant your own personal needs of Boat use.
#5 lateral
lateral
  • 836 posts
  • Locationauckland
Posted 29 April 2019 - 08:20 AM
I have two, doing same job with both going through the shunts to negative battery bus thus monitoring charge and discharge.. (Last device in line is the SG200 shunt)
Only because the cheap BM was already installed and I liked the extra info of the SG200.
You could do the same for redundancy/check or ditch link 20.
If you set them to current draw/discharge, you will soon see what is doing what when you switch stuff on/off.
And what is faulty.
If you have a clamp meter check numbers against your meter.
Both are discontinued years ago, 2008 for link 20. Pretty dumb compared with whats available today.
M2CW
#6 bigal.nz
bigal.nz
  • 159 posts
Posted 29 April 2019 - 09:21 AM
Well I am going to install a Victron MultiPlus and BMV712 - so that will replace the Xantrex. I presume i should leave the Balmar display in since it controls the alternator output?
#7 Island Time
Island Time
  • Administrators
  • 6,792 posts
Posted 29 April 2019 - 09:47 AM
Yes. Put the bluetooth module on the victron. Great history reports and easy to use.
#8 lateral
lateral
  • 836 posts
  • Locationauckland
Posted 29 April 2019 - 09:58 AM
I doubt the balmar dc monitor controls the regulator.
Check the manual on the Balmar regulator that you have; that vintage were usually set on the regulator. Pots, reed switches etc.
I'm not familiar with it
http://www.balmar.ne...inued-products/
#9 bigal.nz
bigal.nz
  • 159 posts
Posted 29 April 2019 - 10:37 AM
Lateral, I think you are right, there is a controller in the electronics bay. Thing in a blue metal case as you say with pots etc - that being the case the BMV712 could replace both the Xantrex and the Balmar monitor? (But the regulator obviously left in circuit).
#10 bigal.nz
bigal.nz
  • 159 posts
Posted 29 April 2019 - 10:55 AM
Yeah they look like a great unit.
