rossd 16 Posted May 7, 2019 Share Posted May 7, 2019 For the last little while only 1 blade has been coming out and have had to blip the throttle to get the other one out. But few days ago it wouldn’t come out even after a couple of rev sessions. In the end stuck it in reverse and then forward and all ok. I think the vibration did some damage to the shaft strut as leaking a bit now. The lesson as always is lack of proactive maintenance will always come back to bite you on the bum. Need another prop, geared folding 2 blade should do the trick. Yanmah 25mm shaft. Existing is 13.5x9 LH , handbook says 13x8.5 and previous paperwork mentions 14x8 so some wriggle room. Anyone got anything or know likely prospects? Thanks Quote Link to post Share on other sites
raz88 96 Posted May 7, 2019 Share Posted May 7, 2019 https://www.trademe.co.nz/2047246717 That looks like a possible? Quote Link to post Share on other sites
wheels 543 Posted May 7, 2019 Share Posted May 7, 2019 Why do you need a new one though. Surely a clean and lube should sort it.Also, unless you have a continuation of vibration even with the prop blades out, the shaft should be OK. If the gland is just a stuffing type, simply tighten up the gland a tad. Quote Link to post Share on other sites
waikiore 398 Posted May 7, 2019 Share Posted May 7, 2019 That is a saildrive prop Quote Link to post Share on other sites
rossd 16 Posted May 8, 2019 Author Share Posted May 8, 2019 Razz88. Sail drive quite different. A spline rather than taper. Wheels. The blades are as sloppy as. It would need a new pin, rebushed and machined blades etc. could be done but also times a problem as no facilities here other than putting down on the boat ramp between tides. I think the shaft, stern tube and gland are ok. It’s the oddball setup where the shafts off the centre line off the boat and has a seperate support strut , which is what took a beating. Quote Link to post Share on other sites
rossd 16 Posted May 8, 2019 Author Share Posted May 8, 2019 Found this listing but wrong hand also boss suspect https://www.trademe.co.nz/trade-me-motors/boats-marine/parts-accessories/propellers/auction-2047249180.htm Quote Link to post Share on other sites
ex TL systems 63 Posted May 8, 2019 Share Posted May 8, 2019 I have a Volvo 3 blade folder on a 25 mm shaft 380 mm diameter ot so 500 with shaft. In New Plymouth though was on a yanmah 30 Quote Link to post Share on other sites
rossd 16 Posted May 9, 2019 Author Share Posted May 9, 2019 3 blades would be cool. Unfortunately 380 or 15 inch will be to big I already have a clearance problem with rudder on full lock. Quote Link to post Share on other sites
rossd 16 Posted June 28, 2019 Author Share Posted June 28, 2019 Bit the bullet and got a new one. Surprised they said a geared one is no more efficient than floppy so floppy it is. What’s the E 19 mean? Also with prop speed it says sand 80 grit so does that mean sand of that nice polished surface?. Do you propspeed the shaft anode? Quote Link to post Share on other sites
Frank 157 Posted June 28, 2019 Share Posted June 28, 2019 That is a Bri Ski Prop and I thought they went out of business years ago ? I found the geared unit was better in reverse, its a Briski on my saildrive and it has given good service. Quote Link to post Share on other sites
rossd 16 Posted June 28, 2019 Author Share Posted June 28, 2019 In business at Maramarua 2 weeks to custom make prop Quote Link to post Share on other sites
Neil C 1 Posted June 28, 2019 Share Posted June 28, 2019 E19 = the date of manufacture - May 2019 Quote Link to post Share on other sites
mattm 98 Posted June 28, 2019 Share Posted June 28, 2019 Prop speed the shaft, but not the anode - it won’t work of covered in prop speed. To make the prop speed stick, you need to key the surface, ie. make it rough by sanding the surface, which will be bad news for the nice shiny surface. Quote Link to post Share on other sites
rossd 16 Posted June 29, 2019 Author Share Posted June 29, 2019 Neil C . How simple, I could have thought of that! Matte . Interesting about the anode. Hopefully the mussels will get spun off! Yes the gloss is going. Quote Link to post Share on other sites
alibaba 76 Posted November 12, 2019 Share Posted November 12, 2019 I've just got a new [ well old!] boat - another Lotus 9.2, The old one was written off in the last Auckland storm. However, this boat has a Yanmar saildrive, [ SD20] with a Briski geared 2-blade folding prop. The propwalk is huge! The boat will NOT go to port in reverse no matter what I do. The last boat had a shaft drive, and I fitted a kiwiprop- just a little propwalk and it worked well. So - hull shape etc is the same, but the boat is really difficult to manoeuvre in reverse. Anyone else with this problem? Any solutions? - apart from lashing out and buying a new prop? -or - is it the saildrive - do they all have propwalk. Quote Link to post Share on other sites
Island Time 1,232 Posted November 12, 2019 Share Posted November 12, 2019 Nope, its the prop... Quote Link to post Share on other sites
chariot 242 Posted November 12, 2019 Share Posted November 12, 2019 Maybe contact the Yanmar agents and see what props they recommend. I have a 3 blade folding Volvo prop on my 9.2 and have very little prop walk. Quote Link to post Share on other sites
alibaba 76 Posted November 12, 2019 Share Posted November 12, 2019 Thanks for the replies. I've tried to contact Briski, but no reply. Had some more practice today and some improvement in my skill, but what certainly doesn't help is the fact that when you hit reverse, nothing happens, unless you hit at least 2500 revs. I guess that's the problem with folders against feathering, the trailing edge becomes the leading edge, which is not very efficient. Might be back to kiwiprop, which is what I had on the last 9.2 Quote Link to post Share on other sites
chariot 242 Posted November 13, 2019 Share Posted November 13, 2019 Which 9.2 did you purchase? Quote Link to post Share on other sites
rossd 16 Posted November 13, 2019 Author Share Posted November 13, 2019 I found Briski great , bit old school but know theif stuff, they will know whats happening, Quote Link to post Share on other sites
