SloopJohnB 323 Posted October 6, 2010 Author Share Posted October 6, 2010 Link to post Share on other sites
Guest Posted October 6, 2010 Share Posted October 6, 2010 That's only one of 6 (from memory) of those they have got. Some impressive numbers all the same. Link to post Share on other sites
Guest Posted October 6, 2010 Share Posted October 6, 2010 How clever of them to build such a vessel.Too bad they couldnt figure out how to stack the containers athwartship so they didnt fall off so easy. Link to post Share on other sites
tuffyluffy 76 Posted October 6, 2010 Share Posted October 6, 2010 I wonder how many litres per hour it gobbles at 31 knots Link to post Share on other sites
Guest Posted October 7, 2010 Share Posted October 7, 2010 Around 7200lts per hour. Heavy fuel oil rather than 95 Mind you the motor is a gentle 109,000 hp, weights 2,300 TONNES, is 13.5mts high, 27.3mts long, 2 stroke 14 cylinder diesel that cruises between 92 and 102 RPM Her sister ships - Estelle Mærsk Eleonora Mærsk Evelyn Mærsk Ebba Mærsk Elly Mærsk Edith Mærsk Eugen Mærsk Here's a shot from above via google maps - http://maps.google.com/maps?f=q&hl=en&geocode=&q=odense&ie=UTF8&t=k&om=0&ll=55.469696,10.532198&spn=0.003479,0.016823&z=16&iwloc=addr Link to post Share on other sites
Farrari 4 Posted October 7, 2010 Share Posted October 7, 2010 Is there only one BIG motor on this monstrosity? What happens if it breaks down. It's not like you can call AA Imagine this beast beam on in rough conditions. Link to post Share on other sites
rigger 47 Posted October 7, 2010 Share Posted October 7, 2010 One main engine - Yes, for more on the E Maersk http://www.authorstream.com/Presentatio ... owerpoint/ Link to post Share on other sites
Guest Posted October 7, 2010 Share Posted October 7, 2010 Mr Rigger, would I be right in assuming one of these beast won't ever be seen here as they are too big of a beast? Assuming it also drank 95, what Emma and her sisters use in one hour would keep my boat going for around 100 years, my wagon for 2 years odd and the weed eater probably until the end of time Shite that's some fuel burn when you look at it that way. If you look at it as a 747 it's knot so good. 7200lts only gets one of those about 600 kms while cruising. Link to post Share on other sites
rigger 47 Posted October 7, 2010 Share Posted October 7, 2010 Mr Rigger, would I be right in assuming one of these beast won't ever be seen here as they are too big of a beast? Assuming it also drank 95, what Emma and her sisters use in one hour would keep my boat going for around 100 years, my wagon for 2 years odd and the weed eater probably until the end of time Shite that's some fuel burn when you look at it that way. If you look at it as a 747 it's knot so good. 7200lts only gets one of those about 600 kms while cruising. At this time a little big - have been told she has a draft of 15m, the main channel is dredged to 12.5m at CD. On the fuel figures how about this - 26000L/day, 4.5knots, 45m long - a little tug towing a barge total length of tug & tow ~1000metres Link to post Share on other sites
Noodles 0 Posted October 7, 2010 Share Posted October 7, 2010 if it drops one of the cylinders in its engine while at sea, they can unbolt the crankshaft and run it on say 10 cylinders. Link to post Share on other sites
Fogg 427 Posted October 7, 2010 Share Posted October 7, 2010 Mr Rigger, would I be right in assuming one of these beast won't ever be seen here as they are too big of a beast? Assuming it also drank 95, what Emma and her sisters use in one hour would keep my boat going for around 100 years, my wagon for 2 years odd and the weed eater probably until the end of time Shite that's some fuel burn when you look at it that way. If you look at it as a 747 it's knot so good. 7200lts only gets one of those about 600 kms while cruising. Yup these ships plying the oceans are actually one of the biggest CO2 polluters on the planet, if you're worried about who the main 'carbon sinners' are. Link to post Share on other sites
rigger 47 Posted October 7, 2010 Share Posted October 7, 2010 Mr Rigger, would I be right in assuming one of these beast won't ever be seen here as they are too big of a beast? Assuming it also drank 95, what Emma and her sisters use in one hour would keep my boat going for around 100 years, my wagon for 2 years odd and the weed eater probably until the end of time Shite that's some fuel burn when you look at it that way. If you look at it as a 747 it's knot so good. 7200lts only gets one of those about 600 kms while cruising. Yup these ships plying the oceans are actually one of the biggest CO2 polluters on the planet, if you're worried about who the main 'carbon sinners' are. I think you need to put it into perspective - imagine the CO2 put into the atmosphere if all that cargo was carried by aircraft rather than ships. Link to post Share on other sites
Guest Posted October 8, 2010 Share Posted October 8, 2010 Looks like they've applied propspeed to the whole hull. Link to post Share on other sites
wheels 543 Posted October 8, 2010 Share Posted October 8, 2010 Quite possibly Hempels new stuff. Link to post Share on other sites
Fogg 427 Posted October 8, 2010 Share Posted October 8, 2010 Mr Rigger, would I be right in assuming one of these beast won't ever be seen here as they are too big of a beast? Assuming it also drank 95, what Emma and her sisters use in one hour would keep my boat going for around 100 years, my wagon for 2 years odd and the weed eater probably until the end of time Shite that's some fuel burn when you look at it that way. If you look at it as a 747 it's knot so good. 7200lts only gets one of those about 600 kms while cruising. Yup these ships plying the oceans are actually one of the biggest CO2 polluters on the planet, if you're worried about who the main 'carbon sinners' are. I think you need to put it into perspective - imagine the CO2 put into the atmosphere if all that cargo was carried by aircraft rather than ships. True but it's why the most radical greenies argue against globalisation cos they say why do this to the planet by shipping sh*t from one country to another, why not make and consume what you need locally, like in the old days. Kind of a bit too late now but you get the point! Link to post Share on other sites
wheels 543 Posted October 8, 2010 Share Posted October 8, 2010 Ummmm, well up till recent years, that's exactly what China and the Us was doing and the result was, China= Poor, USA= Rich. Now we have trade and USA= becoming poor, China- Becoming rich. I wonder if things will eventually balance Link to post Share on other sites
Fogg 427 Posted October 8, 2010 Share Posted October 8, 2010 Which means the only things to come from globalisation is (1) you can buy coke and McDreadful anywhere you go on holiday (2) the poor can now claim redistribution of wealth from the rich and (3) online users can bitch about different marine product prices around the world. Link to post Share on other sites
