Tidying Cables?
10 replies to this topic
#1 L00seM00se
L00seM00se
  • 330 posts
Posted 16 June 2019 - 02:53 PM
I’ve tried everything to attach several power cables neatly to the flowcoat walls. Gorilla Glue, Liquid Nails, ADOS (something) and none seem to last more than a few weeks. Starting to wonder if it’s the plastic things I’m glueing. They are little plastic squares which have a raised middle bit with 4 holes that you can run a cable tie through.
Has anyone used something that works?
#2 Island Time
Island Time
  • Administrators
  • 6,995 posts
Posted 16 June 2019 - 03:25 PM
Yep. Screw down cable tie mounts. Single screw through the middle. All the adhesive ones suck.
#3 Ladyhawk
Ladyhawk
    Member
  • Members
  • PipPip
  • 72 posts
  • LocationTauranga
Little squares of 3M double sided tape (Part # 503-4884) works. I clean the pastic thingy and the wall with acetone or isoprop.
Although as IT says, screw on ones are definitely the go
Edited by Ladyhawk, 16 June 2019 - 03:27 PM.
#4 L00seM00se
L00seM00se
  • 330 posts
Posted 16 June 2019 - 03:47 PM
I’m trying to avoid screwing through the hull, given that there’s sometimes water in the other side
#5 Island Time
Island Time
  • Administrators
  • 6,995 posts
Posted 16 June 2019 - 03:49 PM
The hull will be thick enough, but if in doubt, glue on a little bit of plastic board, screw to that...
  • 2
#6 gisywaterboy
gisywaterboy
    Member
  • Members
  • PipPip
  • 63 posts
Posted 16 June 2019 - 08:31 PM
Ive stuck a few cables on with 3M 5200. 20mm strip every 100mm or so. Worked for me.
#7 Marshy
Marshy
    DayStar
  • 2,530 posts
  • LocationAuckland, New Zealand
Posted 17 June 2019 - 12:11 PM
Just give it a little scuff up with wet and dry sandpaper where you are gluing it- possibly the wax in the flowcoat.
<p>Marshy - I may have gone to the Darkside, but I'm loving the VMG to windward....
#8 44forty
44forty
  • 242 posts
Posted 17 June 2019 - 01:45 PM
I do this but little bits of ply and use bonding silicone . Easy to prise orff with a chisel in the future if it needs to be moved
#9 Dtwo
Dtwo
  • 424 posts
Posted 17 June 2019 - 03:43 PM
Cut a strip of 12mm ply, epoxy to hull, flowcoat.  Then use that to screw your cables to.  Looks neat and professional.
#10 L00seM00se
L00seM00se
  • 330 posts
Posted 17 June 2019 - 06:08 PM
Good ideas re using some ply. Thanks.
