Sailors rescued from life raft after yacht sinks near Whitianga
35 replies to this topic
#11 marinheiro
marinheiro
  • 573 posts
  • LocationCruising Fiji
Posted 16 June 2019 - 09:02 PM
Squander was on her second attempt to go north. She had started with the rally fleet on 28 May but blew her mainsail out the same day in a 50+kt squall leaving the Bay of Is and returned to Opua for repairs.
Pure speculation but I wonder if that incident had caused some damage to the rigging.
#12 MarkMT
MarkMT
  • 933 posts
  • LocationLake Zurich, Illinois or Waiuku, NZ, depending on how I feel. And snow, especially snow.
Posted 18 June 2019 - 12:09 AM
Some additional details... https://www.nzherald...jectid=12241188
The article doesn't mention the original unsuccessful attempt, but this...
The Squander was in "better shape" than when the couple bought it. They'd spent tens of thousands of dollars on it and had its rigging inspected before leaving Opua in the Bay of Islands on June 9.
Ironically, it was the rigging that would fail just three days later.
A steel rod connecting a metal plate at the base of the mast to the boat's superstructure snapped late on the afternoon on June 12, leaving the mast lurching and cracks and splits appearing in the deck.
Who did the rigging inspection?
"And with the type of mast it is, there was a very real possibility … the foot of the mast could have cleared the decks and taken out the liferaft."
What does this refer to? A deck-stepped mast?
Also interesting that they did manage to get 160 litres of fuel transferred from the container ship, so presumably if they'd been able to cut the rig free they could have motored to safety?
#13 waikiore
waikiore
  • 936 posts
Posted 18 June 2019 - 09:15 AM
Rather unclear as to what snapped, it would be good to know for future inspections.
#14 B00B00
B00B00
  • 2,694 posts
  • LocationAuckland.
Posted 18 June 2019 - 09:28 AM
Sounds more like a mastbase/compression post issue than an actual rigging failure?
Quite common in these older production boats with deck stepped masts. Either the posts fail or the deck delaminates when the wood core rots.
Usually a rigging check will probably not pick this up as its a structural boat issue and regardless rigging checks are pretty limited to spotting anything thats actually already broken.
I would not go offshore on a boat with rigging older than 10 years even if it had a satisfactory rigging survey/check.
On our trip from france, 5 boats we cruised with (including us) had rigging either completley fail (one dismasting) or broken strands at the swage.
We broke 5 strands in our D1 stay between Suwarrow and Nuie and were lucky not to loose the whole lot.
One of our friends was not that lucky and lost the rig just out of Tonga and insurance will not pay out due to the fitting that failed being over 10 years old.
Interesting to note that in this case the stay had been replaced but not the rigging screw and it was the rigging screw that failed so no insurance....
Sounds like these guys did have a well setup and maintained yacht and knew what they were doing. Glad no one was hurt but they have lost their yacht which was also their home I believe. Sad story and I hope they have some luck with a salvage or are well insured.
  • 1
#15 Dtwo
Dtwo
  • 368 posts
Posted 18 June 2019 - 10:24 AM
I don't think it sounds like the rigging screw failing.  On a lot of those Euro production boats the lower end of the rigging is connected to a rod that connects to the hull behind the saloon seats.  "A steel rod connecting a metal plate at the base of the mast to the boat's superstructure snapped"  sounds to me as though they had a failure in that rod, or more likely one of the ends.  This would be backed up by their fix of running a line under the hull.  If a rigging screw had failed their fix would have used the existing chainplate/rod.
This would also explain why a rig inspection would not have picked up an issue with the connecting rod - it would be a reasonable expectation that this part of the rig was fine, and you most likely couldn't inspect it unless you pulled the entire assembly out.
#16 Puff
Puff
  • 3,883 posts
Posted 18 June 2019 - 10:58 AM
Yep, one of those suckers there.......
"Never attribute to malice that which is adequately explained by stupidity"
#17 Priscilla II
Priscilla II
  • 1,360 posts
Posted 18 June 2019 - 11:21 AM
Where does the internal shroud base terminate.
Is it to a ring frame.
Attached File  6760450_0_020420191258_20.jpg   302.8KB   3 downloads
#18 Island Time
Island Time
  • Administrators
  • 6,643 posts
Posted 18 June 2019 - 12:46 PM
Thats pretty much the same system as Island Time. The Rods terminate at a large frame, and are through bolted.
#19 Crocket
Crocket
  • 214 posts
  • LocationSydney
Posted 18 June 2019 - 01:28 PM
I read on another web site that they were still able to sail on starboard tack but unable to sail on port, which ultimately led to them getting blown further off shore. However its refreshing to hear of a crew at least trying to make it back. I guess the real story of why they abandoned after the rig ultimately failed will come out in due course.
#20 Fish
Fish
  • 3,317 posts
Posted 18 June 2019 - 02:12 PM
Reading between the lines of that Herald article,  I wonder if the ships crane fouled the mast and brought it down?
I am assuming they were using a crane to transfer the diesel, as it states they had it on a pallet, and had already transferred 160 l.
It would be very easy to foul a mast with a ships crane in the type of sea state they had described.
It would also explain the rapidly changing proposition, and need to be evacuated quickly, after working to bring her back to land for so long.
At 8am yesterday, the captain of the giant container ship – "with incredible seamanship" - brought his vessel in close and successfully offloaded 160 litres of fuel.
But it was a final load of 40L of fuel floating on a wooden pallet that proved the Squander's undoing.
Petrie had just tied it to the back of his yacht and was wondering what to do with it when the ropes snapped at the same time as the mast shuddered and finally gave way.
