vic008 17 Posted September 27, 2019 Share Posted September 27, 2019 Watching youtube "bob the plumber" making a h/exch, and getting ideas. Is this ridiculous? Quote Link to post Share on other sites
Island Time 1,211 Posted September 27, 2019 Share Posted September 27, 2019 Heat exchangers are not complex, but you better have some braising or soldering skills. And you have to work out the flow rates and heat transfer abilities so as to ensure that it will provide sufficient cooling..... Quote Link to post Share on other sites
wheels 543 Posted September 27, 2019 Share Posted September 27, 2019 It depends on how complex you want to make it Vic. The HE's that give the greatest heat transfer for area are stacked full of tubes. A simple oil cooler often has a single tube within a slightly larger tube. Then there are the materials you make it from. Multiple different metals mean the HE needs to have zinc protection fitted. The very expensive ones that do not are usually made from Silicon Bronze and copper, or other such metals within that family. I have seen all SST ones, but they need to be much larger to get the same cooling. Most commonly found in Oil coolers. All Aluminium is another, but once they re shot, they are not worth repairing.I have never built one from scratch, but have had to repair a few that have rotted out. You will be shocked at the amount of tube required to make the core with. Then there is the drilling of the holes in the two end plates the tubes are mounted into. It's a massive job and I have often thought it cheaper to just replace with a new one than rebuild.It could be worth looking into plate coolers. Much cheaper, much smaller footprint, highly efficient. However, the gaps between plates are very small and prone to being blocked up, so you need to have a good inlet strainer. I have talked to manufacturer about using them for marine use and he didn't think there would be any problem other than the filtering. Quote Link to post Share on other sites
Priscilla II 376 Posted September 28, 2019 Share Posted September 28, 2019 Bit of tube in these. I would have thought plate heat exchangers would be at risk from clogging with calcium or mineral deposits. Fascinating things though. Quote Link to post Share on other sites
Chloe 7 Posted September 29, 2019 Share Posted September 29, 2019 Watching youtube "bob the plumber" making a h/exch, and getting ideas. Is this ridiculous? Yep. Just type Bowman heat exchanges into uncle. Quote Link to post Share on other sites
