Wood tiller finish
16 replies to this topic
#1 lateral
lateral
  • 911 posts
  • Locationauckland
Posted 08 October 2019 - 06:59 PM
Last meticulous prep now looks like shite.
It was several coats of west with uv hardener
(407) and six coats of vanish. Didn’t last more than 18 months
And at 3.5 yrs looks like a case of leprosy.
Any proven formulates?
Should have had a cover.
#2 Black Panther
Black Panther
  • Administrators
  • 5,727 posts
Posted 08 October 2019 - 07:31 PM
Sand and revarnish with polyurethane, like they use on wooden floors. Then get a cover.
  Two figures sat side by side, staring at the Sea. One said to the other, “You know that one day we will die.” And the other friend replied, “But all of the other days WE WILL LIVE!”
#3 MartinRF
MartinRF
  • 256 posts
  • LocationStockholm, Sweden
Posted 09 October 2019 - 04:41 AM
I know you live in a sunnier place than I do but still I think it should have lasted longer. What type of wood? Oak and epoxy for instance is non-trivial to make work in my experience.
Then we have tho option of KISS. If swelling/shrinking with variations in humidity is not an issue for this tiller I would consider good old one-pot varnish. Yes, it will need to be re-done on a regular basis but it is not hard work. A cover will extend the service interval considerably.
/Martin
#4 Black Panther
Black Panther
  • Administrators
  • 5,727 posts
Posted 09 October 2019 - 06:10 AM
Ordinary varnish two coats wvery 6months.
#5 Terry B
Terry B
  • 681 posts
Posted 09 October 2019 - 08:43 AM
I took my tiller back to bare wood 6 years ago, epoxied 1 coat then only 4 of spar varnish.
Then got a soft sunbrella cover made.
Still looks like new (apart from where I dropped the boom on it  :roll: ).
It's the cover that protects it I reckon.
TERRY
We live in a society where pizza gets to your house before the police do....................
#6 Vorpal Blade
Vorpal Blade
  • 973 posts
Posted 09 October 2019 - 05:33 PM
When you have finished varnishing it take it to someone to make a fitted cover for it, then install tiller on the boat -  much cheaper than having someone go to the boat and measure/make.
  • 1
for awesome custom made fabric products
http://www.coversandcanvas.co.nz
#7 rigger
rigger
  • 3,521 posts
Posted 09 October 2019 - 08:05 PM
Strip back, 80 to 100 grit,
80/20 thinner/varnish ~ couple of coats
50/50 same
Then 6 to 8 coats for a total of no less than 10.
It may be worth wet sanding after 4 coats for a better finish then another 4 coats.
Get a cover for it, if not wet sand 400 grit and 2 coats every 6 months.
Schooner or gold spar / similar
#8 mcp
mcp
  • 184 posts
Posted 09 October 2019 - 09:02 PM
(407)
207?  ........407 is a fairing compound.
And like above, sand + polyurethane varnish.
#9 lateral
lateral
  • 911 posts
  • Locationauckland
Posted 10 October 2019 - 06:28 AM
Sorry, Yep 207.
So seal coat of epoxy not worth the extra work it seems.
I have ADH30 hardener to make it MORE flexible?
#10 tuffyluffy
tuffyluffy
  • 1,376 posts
Posted 10 October 2019 - 08:47 AM
Timber tillers will look great for at least 5 years with 5 coats of Cetrol . . . . and a cover.
As others have said, a cover will save you a pile of maintenance
