Masking tape
27 replies to this topic
#11 Dtwo
Dtwo
  • 440 posts
Posted 25 October 2019 - 08:50 PM
Thanks for the good advice - one can always rely on you chaps to come up with answers.
So what I'm trying to achieve is a razor Sharp line between the black paint replicating the canopy and the varnish on the rest of the aircraft. Both are sprayed finishes.attachicon.gif 20191022_214410.jpg
I thought I might manage to sell a couple of these models - I didn't count on an order of 50 so I need to get my production and finishes sorted.
Awesome!
#12 idlerboat
idlerboat
  • 1,710 posts
  • LocationVictoria, Australia
Posted 31 October 2019 - 12:50 AM
.....automotive plastic mask.... The stuff designed for twopak.  Just practice a little on removal time.
To short and the finish will string, to long and it will show brittle notches.
There is only two substances..stuff and glue...and even glue is made of stuff,,
quote."MD"
#13 VERGE
VERGE
  • 78 posts
Posted 01 November 2019 - 03:59 PM
You can purchase online here:  https://smitsgroup.c...pes-other-tapes
this might be the one you want: https://smitsgroup.c...-tape-6mm-x-50m
Plane looks great; wish i had that level of craftsmanship.
#14 Chrisc
Chrisc
  • 993 posts
  • LocationWhangamata
Posted 01 November 2019 - 07:19 PM
Thanks for your help with the masking tape. Will chase your recommendation up on Monday.
And thanks also for your comment but it's not skill, it's just having the right tools.
At the moment I have 10 of the spitfire Mk.V's under build and have started on a run of P.51-B Mustangs - but it's all come to a bit of a stop. I need to figure out how to sand the little fiddly bits. No skin left on my fingers and the bloody fingerprints are hard to remove from the wood.
Girl's hands.. but got to pay the expenses on that canal boat somehow..
Young at heart.
Other parts offered without warranty.
#15 Dtwo
Dtwo
  • 440 posts
Posted 02 November 2019 - 03:47 PM
Dremel with appropriate attachment?
#16 Chrisc
Chrisc
  • 993 posts
Posted 02 November 2019 - 07:58 PM
Young at heart.
#17 Chrisc
Chrisc
  • 993 posts
Posted 02 November 2019 - 08:19 PM
Yep, got a Dremel but it's a bit vicious on little bits.
After a bit of experimenting this is what I've come up with if anybody has a similar problem.
I cut a 300mm piece of 5mm steel down to 25mm wide. One end is clamped in the vice and the rest of the bar sticks out on the side of the vice you want to work on - depends if you're right or left handed. On the bar I put a bit of 25mm emery tape held on with a tiny ratchet clamp on each end.
The little bits I want to shape and sand are very thin and only 10-20mm long, but the bits are cut 20 - 30mm longer to provide something to hold on to. When finished, the handle part of the job is cut off and the piece will need just a couple of whisks over the sandpaper to tidy up the cut off. Holding the bit between thumb and forefinger, the front part of the forefinger runs along the edge of a steel bar which gives good control but just make sure it is properly de-burred.
Young at heart.
#18 Chrisc
Chrisc
  • 993 posts
Posted 21 January 2020 - 08:30 PM
This masking off paint lines is driving me insane!
On these models I sand to baby's bum smooth, spray two coats on varnish, sand with 400grit,then mask and spray some parts with black paint. I bought some eye wateringly expensive detailing tape as advised in posts above but am still getting a degree of undercutting. And what do you do about corners where one line of tape overlaps another? There is always a paint dribble there. The attached pic shows the aircraft canopy in black AFTER an hour of delicate clean up of the paint line with a scalpel, and it's still not all that good. There's got to be an easier way.
And I realize that this query has nothing to do with boating except that if I can keep selling these things then we can afford to keep canal boating starting April.Attached File  Bf109.JPG   1.49MB   0 downloads
  • 1
Young at heart.
#19 Chrisc
Chrisc
  • 993 posts
Posted 21 January 2020 - 08:31 PM
Young at heart.
#20 Chrisc
Chrisc
  • 993 posts
Posted 21 January 2020 - 08:32 PM
Young at heart.
