vic008 17 Posted November 24, 2019 Share Posted November 24, 2019 There is a buzzer test button beside the power on/off button. So turn power on should buzzer sound or only sound when you push the test button? (It sounds when power on) Quote Link to post Share on other sites
kiwi_jon 26 Posted November 25, 2019 Share Posted November 25, 2019 Should sound on power on to indicate no oil pressure. Should silence once diesel started and oil pressure built up. Test once diesel has started Quote Link to post Share on other sites
Island Time 1,235 Posted November 25, 2019 Share Posted November 25, 2019 There is a buzzer test button beside the power on/off button. So turn power on should buzzer sound or only sound when you push the test button? (It sounds when power on) That is exactly what it should do. Then turn off pretty quickly once engine going ( a sec or 2) Quote Link to post Share on other sites
tuffyluffy 76 Posted November 26, 2019 Share Posted November 26, 2019 I have the same engine and the buzzer sounds on cold idle until I give it a few revs - I should probably adjust my idle speed Quote Link to post Share on other sites
Island Time 1,235 Posted November 26, 2019 Share Posted November 26, 2019 TL, oil pressure might be low at idle - often an early sign of worn pump or bearings... Quote Link to post Share on other sites
vic008 17 Posted November 26, 2019 Author Share Posted November 26, 2019 Sparky booked for tomorrow Quote Link to post Share on other sites
