Difficulty in gear selection
2 replies to this topic
#1 SanFran
SanFran
  • 331 posts
  • LocationAuckland
Posted 02 December 2019 - 06:01 PM
I've just had to replace the throttle cable. Single control with the press button to disengage gearbox type. I've got a 20hp buhk and don't know how to set the idle rpm. Might be a bit high, so would this be the cause of the difficulty in getting it into and out of gear. Reverse is especially difficult.
Ships are safe in harbours, but thats not what ships were made for.
#2 Island Time
Island Time
  • Administrators
  • 7,082 posts
Posted 02 December 2019 - 06:11 PM
First thing is to remove the cables from the engine and gearbox.  Set the idle speed correctly on the engine then try a gearshift by hand at the gearbox lever. If its still hard its a gearbox issue, if its easy its cable setup.
Idle is set by ensuring the throttle lever comes right back to the stop, which is usually moved with an adjustment screw....
#3 SanFran
SanFran
  • 331 posts
  • LocationAuckland
Posted 02 December 2019 - 08:59 PM
Excellent. Thanks. Understood, I think it's a few mm off the stop, so will be my first adjustment, test
