alibaba 76 Posted December 20, 2019 Share Posted December 20, 2019 Yanmar 3gm. Press start button- nothing happens until, after random presses, I get a connection. I seem to remember reading about this a few years ago, but I have lost the reference. Something to do with replacing a small gauge wire from the start button to the solenoid? Anyone enlighten me with a fix please? alibaba Quote Link to post Share on other sites
Island Time 1,233 Posted December 21, 2019 Share Posted December 21, 2019 Pull the small wire off the solenoid. Use a temp wire to connect that terminal to the batt + , and the starter should go. If not, faulty solenoid, if yes, faulty start switch or wiring. Quote Link to post Share on other sites
vesper1 3 Posted December 21, 2019 Share Posted December 21, 2019 I have a Yanmar j series and there is a small gauge wire from the start switch to a relay. The start switch energises the relay which activates the starter solenoid etc. The relay is situated on the engine. It works well and is a way of getting around a voltage drop on longer runs of light gauge wiring. Quote Link to post Share on other sites
Winter 42 Posted December 23, 2019 Share Posted December 23, 2019 I have a spare (used) start button and key switch for a Yanmar 3GM if you want it Quote Link to post Share on other sites
alibaba 76 Posted December 24, 2019 Author Share Posted December 24, 2019 That's very kind of you, but I think it will do me good to fix the problem. I've improved the connections and the problem has gone away for the moment. If it comes back , I'll take the above advice and fit an extra relay. Thanks all your your help. cheers Quote Link to post Share on other sites
