rossd 16 Posted January 11, 2020 Share Posted January 11, 2020 IT. I am wiring up an optolamp i got off you. I thought i was going to be able to use the all round white as a steaming light as well as anchor but the 3 way switch supplied allows only tri or anchor not both together. Could i wire the 2 grey wires on seperate switches so as to use both at once? I am not interested in the strobe. Quote Link to post Share on other sites
Island Time 1,211 Posted January 11, 2020 Share Posted January 11, 2020 No, sorry, that's not what possible. The two greys are anchor (all round white) with the polarity one way, and tricolor with polarity the other way. The third wire is only used for strobe. Plus you are required to have sidelights min 1m below a steaming light, which cannot be done from one fixture.... Quote Link to post Share on other sites
rossd 16 Posted January 11, 2020 Author Share Posted January 11, 2020 Yes looking at wires again I thought maybe not posable. Mind i also have low nav lights so masthead white ok wirh them. Bit late now though.would have needed seperate white up there Quote Link to post Share on other sites
Island Time 1,211 Posted January 11, 2020 Share Posted January 11, 2020 Yep, you can use the white all round as a combined steaming and stern light, if under 12m.... Quote Link to post Share on other sites
