Solar panel
5 replies to this topic
#1 Nzgrant
Nzgrant
  • 135 posts
Posted 15 January 2020 - 06:55 PM
I have a solar panel that shows acceptable volts 17 plus but only half an amp when plugged into controller. Is this how solar panels die??
#2 Island Time
Island Time
  • Administrators
  • 7,083 posts
Posted 15 January 2020 - 07:07 PM
Sometimes, yes...
#3 mcp
mcp
  • 200 posts
Posted 15 January 2020 - 09:04 PM
Could also be corrosion in the wiring.    Is there a sticker on the panel showing specs and do you have a multimeter?
#4 wheels
wheels
  • 16,818 posts
Posted 16 January 2020 - 03:48 AM
What size panel?
Are you measuring OC voltage or measuring when it is connected? 17V is not a lot for OC. It should be in the mid twenties.
#5 Nzgrant
Nzgrant
  • 135 posts
Posted 10 February 2020 - 02:26 PM
Panel elfland solar panel SP-37
100watt
Ipmax 5.5A
Vpmax 18V
Isc 6.1A
Voc 20V
32 cells
Flexible panel
Panel is pretty rough looking. Took little box off resoldered panel to it.
connections are pretty rough.
Oc was 19 in fullsun today was getting between 15 and 18volts when connected to controller but was only getting 0.4amps other panel getting similar volts but 2.6 to 3amps
#6 wheels
wheels
  • 16,818 posts
Posted 11 February 2020 - 05:16 PM
Well if one is performing and the other not, I guess that's question answered.
