Nzgrant 19 Posted January 15, 2020 Share Posted January 15, 2020 I have a solar panel that shows acceptable volts 17 plus but only half an amp when plugged into controller. Is this how solar panels die?? Quote Link to post Share on other sites
Island Time 1,211 Posted January 15, 2020 Share Posted January 15, 2020 Sometimes, yes... Quote Link to post Share on other sites
mcp 32 Posted January 15, 2020 Share Posted January 15, 2020 Could also be corrosion in the wiring. Is there a sticker on the panel showing specs and do you have a multimeter? Quote Link to post Share on other sites
wheels 543 Posted January 15, 2020 Share Posted January 15, 2020 What size panel?Are you measuring OC voltage or measuring when it is connected? 17V is not a lot for OC. It should be in the mid twenties. Quote Link to post Share on other sites
Nzgrant 19 Posted February 10, 2020 Author Share Posted February 10, 2020 Panel elfland solar panel SP-37 100watt Ipmax 5.5A Vpmax 18V Isc 6.1A Voc 20V 32 cells Flexible panel Panel is pretty rough looking. Took little box off resoldered panel to it. connections are pretty rough. Oc was 19 in fullsun today was getting between 15 and 18volts when connected to controller but was only getting 0.4amps other panel getting similar volts but 2.6 to 3amps Quote Link to post Share on other sites
wheels 543 Posted February 11, 2020 Share Posted February 11, 2020 Well if one is performing and the other not, I guess that's question answered. Quote Link to post Share on other sites
