Rubber rub strip
I have the two back corners of a rubber rub strip (black) slightly damaged and I want to repair them to enhance the look of the boat. I have lightly sanded them and need a product to bring back the shine?
Any suggestions Thanks
If it is rubber, heat won't change it.
If it is a plastic, then yes, but you have to be VERY careful because you are actually melting the surface and it goes from "nearly there to oh B#$(@#&r in a fraction of a second. And if it goes wrong, there is no fixing it.
