Changed 10 Posted April 29, 2010 Author Share Posted April 29, 2010 I was going to try to do away with the drag that would be created with the boot. Rise and fall - I have a Harkin Magic box I was going to use Link to post Share on other sites
Guest Posted April 29, 2010 Share Posted April 29, 2010 pt dry run top Link to post Share on other sites
Guest Posted April 29, 2010 Share Posted April 29, 2010 will it work Link to post Share on other sites
Guest Posted April 29, 2010 Share Posted April 29, 2010 well I motored to westpark under new flash volvo 20 with all the bells and whistles, sat on 8.5knts in the sweet spot ( my god way over powered ) the boat draged its arse and you could have probibly just surfed the transom wave. 25 hours old, the volvo was pull and went to a more fitting home. PT owners motor choice was a tohatsu 18hp 2 stroke from cams automotive & mirine, we fitted a 4 blade high thrust prop as well. now the motor was brand new and had to be run on an oily mix, I was told load is ok but don't ring it. so off back to town i go motor sounding sweet, no water backwash up well no transom drag, just a flat clean wake. I hadn't conected the instuments back up, so grabed my gps out of my bag and 9.2knts over ground with ease. ok there may have been a bit of tide but I must say I was impressed considering the motor had lot more availble. got to westhaven and tried reverse etc oposite A pier prior to docking, and yes its a great prop as well. So cat 1 may be an issue, but i'm sure the set up would easily get cat 2 , key start , remote throttle, perminent home etc etc and just a string for up and down. Link to post Share on other sites
Guest Posted April 29, 2010 Share Posted April 29, 2010 I forgot to add as with waka the motor can be easily removed without removeing the carrier. just with pt you've got to drop the hull plate to pull the carrier ( only 6 machine skrews ) Now regarding cat 1 thunder has a retacting outboard set up in the cabin 25hp 4 stroke from memory - someone should ask Brian what the issues were are if any getting cat 1 Link to post Share on other sites
Guest Posted April 29, 2010 Share Posted April 29, 2010 And one more Link to post Share on other sites
Guest Posted April 29, 2010 Share Posted April 29, 2010 Do you bother trying to remove the water after it is raised or just let it live inside a wetbox? Link to post Share on other sites
Murky 1 Posted April 29, 2010 Share Posted April 29, 2010 You do a bloody good job FnG. Link to post Share on other sites
Guest Posted April 29, 2010 Share Posted April 29, 2010 with pt there was close to 9ltrs of water, I hollowed the hull plate aft for water flow and had it set so it could syphon. do'nt know if it did or not. but even with the 9ltrs/ kgs of water they were still better by miles on the diesel weight/ drag Link to post Share on other sites
Guest Posted April 29, 2010 Share Posted April 29, 2010 In the stowed position is the engine/prop clear of the water. BTW I agree - nice work. Link to post Share on other sites
Guest Posted April 29, 2010 Share Posted April 29, 2010 typically no, pt has about 250mm of hull rocker so I guess the water pump would just be out and the top of the prop. We set up remote flush kits so you can attach the hose and give them a rinse. Link to post Share on other sites
Guest Posted April 29, 2010 Share Posted April 29, 2010 That looks like a bit of me. So the whole bracket/outboard is raised via a tackle system, it that all? And does it get 'locked up' or just hang off the tackle system? Out with the chainsaw and pink bog Link to post Share on other sites
Murky 1 Posted April 29, 2010 Share Posted April 29, 2010 Two words: webcam please. Link to post Share on other sites
Adrianp 116 Posted April 29, 2010 Share Posted April 29, 2010 Hey FnG. do you have a photo showing the old sail drive. Wasn't it very close in diameter to the keel bulb? Link to post Share on other sites
Adrianp 116 Posted April 29, 2010 Share Posted April 29, 2010 For thiose that have these systems, how do you find the noise? I've been on a couple of boats with these and they seem to make alot of noise, vibration and fuss for the amount of go they have? Perfect idea for a 30ft boat though! Link to post Share on other sites
Changed 10 Posted April 30, 2010 Author Share Posted April 30, 2010 Thanks fr all the effort in downloading the photos and the carrier design. much appreciated. Link to post Share on other sites
Guest Posted April 30, 2010 Share Posted April 30, 2010 From me to. It has helped clear the mind of some rather weird ideas. Now have to tweak my mold but that's ok. All for the greater good. Link to post Share on other sites
