I have a BF20 that's on a trailer sailer that I've been given and am trying to sell (http://www.trademe.co.nz/Browse/Listing.aspx?id=891439399). Seems like a really nice motor for the few times I've used it. 6amp charging as standard and can be upgraded to 12amp I think? If you want to help unbolt it, your welcome to borrow it to see how it fits and goes. I'm really hoping I can sell the boat without the motor as I really want to keep it for cruising on Freedom/hooning around in my RIB.
Mine seems to have a smaller prop than the 9.9 yamahas run so that might be a point of difference. I don't know if mine is a high thrust model.
I think I remember Phil saying Sundreamer has one of each at the moment and he is trying to go back to the yamahas?
Share this post
I've had two Honda's on Pulse. First one was a 15 hp, the old square model as it was the last one to be upgraded into their current form. It was a very good and reliable engine. A year overseas and not getting used probably killed it, eventually getting gear box problems and a cracked water jacket. Still it did nine years without getting flushed of course.
Then there was a 15 hp 'Sail' outboard. It was called a 'Sail' because mostly that is what I did as it was hopeless. Stay well clear.
Now I have a 10 hp Honda, only because there wasn't a 15 hp available in the country just before a Coastal when I needed to replace the above quickly. It has an impressive 12 Amp charging and electric start. It's been mostly reliable, a few niggles. It has a vibration at mid revs, but could be in the boat. I miss the extra 5 hp only when going from forward to reverse. I've got the biggest 4 blade prop with fine pitch I could find.
On the whole I've been more than happy with the Honda's I've had.
Share this post
Only decent picture I could find! Just in response to the Accord comment above it really.
I once had an outboard called a Wind 8hp, was made in Russia by a company called Volga motors (seriously). Fantastic motor, ran like a dream once they replaced the faulty ignition coil they'd all been shipped with! If I still had it, I'd be using it!!
Apparently the Wind was more reliable than Tim's Sail :)
Share this post
an old thread
but have been researching prop specs
as previously stated
the yamaha 8hp 2-stroke is a high power, low weight,  popular choice for 8.5mt multis
it comes standard with a large pitch 10'?  all white prop designed to get light dinghies planning
there are also 2 lower "geared"  "dual thrust" options for boats heavier than a dinghy that will never reach those speeds
the black hubed  9" x 7"N, for light weight multis (9 inch diameter with 7 inch pitch)
 (cast into the prop alloy)
and the black hubed 9" x 5"N for heavier boats with heavy keels
the black hub is "dual-thrust" in yamaha speak, which means in-hub exhaust so the blades are less likely to cavitate in reverse and lose bite.............most light tinnys/inflatables etc don't reverse much so don't need this exhaust gas diversion
solas also make 5 props for the yami 8hp 2 stroke, the 4 bladed versions with in-hub exhaust probably the best choice for multis
http://www.rubexprops.com/boat-propellers/Yamaha/?motor=H0080C&ver=a&model=8HP%202%20Stroke%20(7%20Spline)
yachts heavier than 900kg probably want more power AND lower gearing
for them the 9.9hp was made with lower reduction gearing to prop (planing speeds not needed)
AND a range of dual thrust props for differing boat weights
cavitation protection in swells
small multis with a single outboard mounted centrally seem better with the long shaft engines as the hulls can lift the prop out in swells + waves
yamaha make just the 1 long shaft option but tohatsu make a long and an extra long
as Greg has on Mysterex
but even the standard long shaft yamaha can still get lifted clear enough for the engine to scream as the prop half spins in air.......one way to help prevent this is to bolt an aftermarket hydrofoil to the engine's small anti-cavitation plate just above the prop
http://www.trademe.co.nz/motors/boats-marine/parts-accessories/outboards/auction-1168791372.htm
the barnys fitted 1 to capricorn's 8hp 2-stroke yami
and it seems to be working well
they are just a cut + bent bit of alloy sheet so am going to knock up another out of some spare ally checker-plate for the spare engine
also outboard mounts that have multiple down positions help to keep the prop from spinning free
capricorn is set so the 2nd from bottom hole for motoring off the mooring, with sails already raised
but need the max bottom setting for motoring in, as when head to wind to drop sails, my weight moving from stern to bow, can lift the prop clear from the 2nd from bottom position
Share this post
It's not cavitation. It's ventilation. Air being sucked down to the prop from the surface.
Cavitation is very unlikely on the small outboards and speeds we operate at.
Share this post
