Island Time 1,220 Posted October 20, 2015 Share Posted October 20, 2015 I was asked a question I could not answer by a friend rebuilding an alloy boat. It has alloy water tanks. He's been given all sorts of conflicting advise about using the alloy tanks for drinking water. So, do any of you industrial chemist types know the real story with alloy tanks? Interior left alloy or should be painted? If painted, with what? Is there any reason Chlorine cannot be used for water sterilisation? Best way to clean out a used tank with very limited access. What do you all think, and does anyone actually know? Thanks Matt Quote Link to post Share on other sites
tuffyluffy 76 Posted October 20, 2015 Share Posted October 20, 2015 I'm no chemist, nor do I know much about about alloy water tanks, however I do own an alloy keeler with two 90 litre alloy water tanks that are at least 25 years old. Here's what i know. . . . They arent painted. Ive only ever used the standard water purification tablets in them from the chemist and never had a problem, I don't know if they contained any chlorine I filled mine up with a concentrated bleach solution, left them for a few days then flushed. So far I've never had a problem with them. There does seem to be a lot of slightly informed, opinionated 'experts' on all things alloy around and little of their advice has been worth listening to. Quote Link to post Share on other sites
Steve Pope 243 Posted October 21, 2015 Share Posted October 21, 2015 Ditto Tuffy Luffy, I have 2 x 200l tanks, 35 years old, I did open them up 10 years ago, but only because I wanted to inspect them, I replaced both lids as there was some minor pitting on the underside, not sure what had caused it. We have used clorinated Auckland / Whangarei water to stream water from the barrier, and whatever we could get up in the Islands. No issues. Quote Link to post Share on other sites
Island Time 1,220 Posted October 21, 2015 Author Share Posted October 21, 2015 I've been researching this a bit today. Seems that long term, chlorine in alloy tanks is not a good idea. Probably what caused the pitting in your lids KM. Some users report white powder/crystals in the water, sometimes clogging the pumps/strainers. This is oxidization of the alloy. Apparently the chlorine accelerates the oxidation. The recommendation is to use peroxide to sterilize the water and clean alloy tanks. This is all 2nd (or 3rd) hand though, I'd like to hear from someone who really knows this stuff!! Quote Link to post Share on other sites
Beccara 25 Posted October 21, 2015 Share Posted October 21, 2015 The chemical path is 2AL + 3CI form's ALCL3 and is the white chalky substance they will be talking about. You can see an advanced reaction rate if you heat foil and dip it in a heavy chlorine solution. Without heat this reaction is fairly slow and I doubt you'd live long enough to see it eat a hole in a tank. Having said that ALCL is a nurotoxin with heavy links to motor function based illness's and whatnot. If you cant avoid the use of the material then i would seal it with a food safe sealer, Take your pick of epoxies or whatnot - even 291's approved for water Quote Link to post Share on other sites
wheels 543 Posted October 21, 2015 Share Posted October 21, 2015 About 6 or so years ago, I built two 650ltr tanks out of Ally. One for fuel and one for water. I was nearly finished when I had the client come to me in a panic. He had another contractor tell him he couldn't use Ally for fresh water holding. Thinking that was the stupidest thing I had ever heard and that I was using a Marine grade Ally that has a high degree of corrosion resistance, but at the same time knowing the Contractor and knowing he was not an idiot, I went and had a talk to him about it. The story was that the big Mussel Boats working out of Havelock were having big trouble with the fresh water becoming tainted and undrinkable. They sent samples to the Cawthorn institute for testing and the result came back that something (He couldn't remember what it was) in the fresh water in Havelock, was reacting with the Ally and producing a chemical that was causing the problem. So I ended up coating the inside of the fresh water tank, to stop contact with the water. I don't remember Havelock having Chlorine added, but it may have perhaps.Beccara is correct that Aluminium and Chlorine react to produce Aluminium Chloride. ALCL3 is a white powdery stuff and is often seen around a little pitted hole. However, Aluminium Oxide is also the exact same in appearance and affect and so the only way to distinguish between the two is to have it chemically tested. But once ALCL3 is created, it doesn't always stop there. ALCL3 can go on to react with other trace elements that are common to find in fresh water. Such as, Iron, Calcium and Magnesium. One trace element found in ground water in some areas around NZ is Arsenic. I don't know what that would if it could create, but it is highly likely it will make something nasty. Quote Link to post Share on other sites
Island Time 1,220 Posted October 21, 2015 Author Share Posted October 21, 2015 OK, so then the consensus is that it is probably best not to use chlorine in alloy tanks. What about peroxide for sterilisation then? To paint the inside of these tanks would require major surgery (very limited access - they would have to have hatches cut, lids made etc), and replacing them is not really an option... Anyone used peroxide before? Is it chemically safe with alloy, can any taste be removed with a carbon filter etc... Quote Link to post Share on other sites
Beccara 25 Posted October 21, 2015 Share Posted October 21, 2015 Yeah it's pretty safe, Handbook of corrosion say's Aliminium is used in distilling and transport making reference to Alloys 1060,5052 and 6063. You may accelerate or build current oxide deposits in the tank due to the strone oxidizing nature of peroxide but you'd kill any bugs. A 100 micron filter would pick up most of the free floating oxide deposits without clogged up every week Quote Link to post Share on other sites
Island Time 1,220 Posted October 21, 2015 Author Share Posted October 21, 2015 OK, so if peroxide will create oxidisation of the alloy, and chlorine will create the ALCL3, then it seems to me it does not matter which you use as long as you filter before drinking?? Which one of the two would cause less deposits then ?? Quote Link to post Share on other sites
Beccara 25 Posted October 21, 2015 Share Posted October 21, 2015 Oxide isn't too bad in that it's fairly safe to humans, AlCL3 is not safe and is a know nurotoxin. There's two things here, One is the water it's self - Taking city supply to fill your tanks will create ALCL3 in your tank that will hang around in your water supply so either do rain collection or filter the city water in fresch charcoal filters. The next thing is tank cleaning which your specifically asking about - Using either peroxide or chlorine should always result in a very good rinsing of the tank with pure water only to prolong the tank life and avoid pinhole leaks. It's safer on the user to use peroxide to clean the tank for the user and the tank. The creation of deposits at what rate is rather hard to say, temp, agitation rate, concentration of the cleaner and the level of biological contamination will all change it hugely. Best advice I can give is filter water coming into the tank (Depending on source 50/25/5 micron and charcoal) and coming out of the tank aswell,100/50 micron to protect the pump and avoid blocking taps etc, Charcoal i would put also past the pump if the water in the tank is not being cycled often. 3% peroxide to clean anything biological and the ice cubes + bumpy ride to "scour" the deposits on the bottom of the tank Quote Link to post Share on other sites
wheels 543 Posted October 21, 2015 Share Posted October 21, 2015 Excellent Beccara. Do you have chemsitry knowledge? Carful how you answer that, because a yes may mean you will have lots of questions from me in your PM box Quote Link to post Share on other sites
Beccara 25 Posted October 21, 2015 Share Posted October 21, 2015 Ha! Most of it's just basic's supplemented by an energy project I worked on a while ago around biomass gasification and biogas digesters and subsequent operation and maintenance challenges in new plants. Quote Link to post Share on other sites
Island Time 1,220 Posted October 22, 2015 Author Share Posted October 22, 2015 Thanks Beccara !! I'll pass all that on to my friend... Quote Link to post Share on other sites
DrWatson 374 Posted October 23, 2015 Share Posted October 23, 2015 If you do have alloy tanks... NEVER USE CAUSTIC SODA ...ahhh fun times... Quote Link to post Share on other sites
Guest Ketchup Posted October 24, 2015 Share Posted October 24, 2015 Painting alloy tanks is a tricky but beneficial exercise. Basically Its the same system as painting alloy for emersion but a specialized Potable epoxy ( non amine) is used. System is Clean/degrease (used tank) then Blast to SA2.5 (>15 micron profile) Etch 300microns DFT of potable epoxy. Clean/rinse washout For adhesion a Blast profile is best but this cannot be done to a existing fabricated tank. There are various methods from pre abrasive blasting the internal surfaces before manufactur to acid etching/flushing of existing tanks. If your tanks has big inspection ports then application can be easier with specialized spray guns. Or even brush and rollers. With limited access you can do the whole process by calculating the internal surface area and then processing each stage with calculated qty's of each product. And using The "fill swirl and empty process follows bY forced air drying. It is quite a science and very similar to how we coat the internal surface of hundreds of kilometres of gas pipeline around the world. You don't have to paint alloy tanks. but doing so prolongs its life and keeps it cleaner longer. Quote Link to post Share on other sites
SanFran 12 Posted October 27, 2015 Share Posted October 27, 2015 Sorry to be a dodo but I have been following this thread. Just to be ssure can you define 'alloy' tanks? I take it that it doesn't include stainless steel? Quote Link to post Share on other sites
SanFran 12 Posted October 27, 2015 Share Posted October 27, 2015 I have a couple of pin holes weeping in stainless tanks. Is it possible to float on a stainless weld over these? Quote Link to post Share on other sites
wheels 543 Posted October 27, 2015 Share Posted October 27, 2015 Yes Alloy is the wrong term. We have been referring to Aluminium in this thread and it should be abbreviated as Ally, not Alloy, just so to be clear, seeing as Alloy means the mixing together of two or more different metals to make a new metal, or improve a Metals properties.Now re your SST issue. Yes it is possible. If you can get the tanks out, then any SST fabricator should be able to weld the holes up just fine. If you can not get them out, then there is also a possibility of welding them in place, if the hole can be got at easily enough. A small portable TIG welder will do the job, but it would be a case of trying to find a SST fabricator that has a wee portable unit.Or if you want to, you can also use Epoxy Putty like Selleys Need It or Emekit. I have used both and both a good. I know carry Knead It as part of my onboard spares. Brilliant stuff. I have even repaired Fuel Tanks and had those repairs last for years. Quote Link to post Share on other sites
SanFran 12 Posted October 27, 2015 Share Posted October 27, 2015 Great thanks. I have the tanks out so should be no problem. Quote Link to post Share on other sites
SanFran 12 Posted October 28, 2015 Share Posted October 28, 2015 Another question if I may be so bold... my welder suggests it would be a good idea to attach a tag to the tank and have a wire to the engine block (to the anode). The pitting may be from electrolysis from a nail or something under the berth. Thoughts anyone? Quote Link to post Share on other sites
