Mast corrosion
Hi all,
I went to look at a boat today and saw some corrosion on the aluminum mast. The corrosion occurred just below the rubber boot seal where the mast goes through the cabin roof. The corrosion formed a 3mm hole all the way through the mast at the leading edge.
Does anybody here have any experience with this type of problem? Is it a problem?
never good to have corrosion all the way through
but 3mm is only a small rivet hole
so nothing to worry about in itself
but you do need to look closer for more corrosion
erice is right.
Is it easy to drop the mast? i.e. small boat? Various solutions can be used to fix the issue, but we would need to see a pic or to. There are several current and past Rig guys here in Crew and could offer the best solution.
