Bad Kitty 252 Posted October 7, 2017 Share Posted October 7, 2017 Can people running Ididum Go tell me, are you running external aerials or just the little fold up jobby? Nav station is in the saloon, foam & glass cabin top overhead. Any experience on how reception will be? Quote Link to post Share on other sites
clareb 1 Posted October 8, 2017 Share Posted October 8, 2017 We haven't set our external aerial up yet and aren't getting great reception with just the fold up aerial. Texts are fine, calls seem to have a delay and drop out. Quote Link to post Share on other sites
southernman 73 Posted October 8, 2017 Share Posted October 8, 2017 External aerial, absolute must especially in a seaway. Although on a cat you might just get lucky if you have a clear pathway to the sky. Quote Link to post Share on other sites
Battleship 100 Posted October 8, 2017 Share Posted October 8, 2017 Have an external antennae on ours, worth ever penny,connects first time every time, calls are reliable and downloading weather gribs is also reliable. Used in the last RNI and didn't matter how rough or which way the boat was facing. Quote Link to post Share on other sites
wild violet 38 Posted October 8, 2017 Share Posted October 8, 2017 Used one for 6 weeks earlier this year with only the small aerial,urther south we went worse it worked,we were only sending texts on it and sometimes had a 20 min lag.For what they cost to run i would get a satphone next time. Quote Link to post Share on other sites
1paulg 17 Posted October 8, 2017 Share Posted October 8, 2017 I was told if the iridium worked ok without an external aerial ( ours does) a Go most likely will too- can’t confirm that from personal experience yet though Quote Link to post Share on other sites
idlerboat 116 Posted October 9, 2017 Share Posted October 9, 2017 external ant much better, but just received a weather forecast request txt from one with no ext ant 2 minutes ago .... Quote Link to post Share on other sites
southernman 73 Posted October 9, 2017 Share Posted October 9, 2017 If I disconnect the external antenna on ours and try and use it I loose 2 bars of reception. Makes a huge difference. However I used one the other week on a cat that was installed with the internal antenna 'looking' through the front glass window and it worked ok. Probably best to try and see if you are worried about the cost, if not run with the antenna. Quote Link to post Share on other sites
Bad Kitty 252 Posted October 9, 2017 Author Share Posted October 9, 2017 If I disconnect the external antenna on ours and try and use it I loose 2 bars of reception. Makes a huge difference. However I used one the other week on a cat that was installed with the internal antenna 'looking' through the front glass window and it worked ok. Probably best to try and see if you are worried about the cost, if not run with the antenna. No there's an aerial already there for an Iridium phone cradle, just thinking we might be able to lose it. But for 2 bars of coverage I'll keep it. Thanks for the input y'all, Quote Link to post Share on other sites
John B 106 Posted October 10, 2017 Share Posted October 10, 2017 I was advised to get the aerial B K. Been great for the last 5 months at 17 or so.and in between. Quote Link to post Share on other sites
darkside 61 Posted October 10, 2017 Share Posted October 10, 2017 Any idea of the costs of making a call to a "go" I see some retailers claiming they can get better deals. Quote Link to post Share on other sites
B00B00 310 Posted October 10, 2017 Share Posted October 10, 2017 With our one I think it would work without the aerial as it mostly has near full reception but the download speed seems to be much faster with the external aerial and 5 bars reception the whole time. With the time it can take to download some files you really can't have any breaks in reception over that time or it 'times' out. Quote Link to post Share on other sites
