NZTiger 17 Posted September 19, 2019 Share Posted September 19, 2019 I'd be interested to know if anyone operates an autohelm or tillerpilot on an 8.5 multihull. I'm thinking that it would be useful for sail changes and deck management if you're shorthanded or sailing with non-sailors. I imagine actually sailing with one would be quite inefficient relative to having a capable human on the tiller. I also realise that there are certain conditions where you wouldn't want to leave the steering responsibilities up to a robot which can't feel the wind gusts. If anyone has any experience with one I'd be keen to hear about it. Cheers, Justin Quote Link to post Share on other sites
Deep Purple 511 Posted September 19, 2019 Share Posted September 19, 2019 Not an 8.5 but I used to use one a lot on my turissimo 10, even able to fly a hull while the autohelm steered from the leeward cockpit. Quote Link to post Share on other sites
Island Time 1,227 Posted September 19, 2019 Share Posted September 19, 2019 It's no problem. But use a fast pilot, like the TP32 navico/simrad. Better, but more $ unfortunately. Of course, be careful in a multi ! Quote Link to post Share on other sites
Clipper 343 Posted September 19, 2019 Share Posted September 19, 2019 I used to have 2 St2000 tillerpilots on voom, one in each cockpit. Used them a lot when singlehanded racing. Brilliant. Made hoists, drops and peels so much easier. If its breezy, just need to be running deep to do kite stuff. Also made long motoring trips much more pleasant, not having to steer Quote Link to post Share on other sites
NZTiger 17 Posted September 20, 2019 Author Share Posted September 20, 2019 Thanks for the feedback. Looks like they have their place. I'll probably select the model based on room constraints in the cockpit. Saying that, I quite like the idea of a wireless controller which could persuade me down a certain track, particularly if I want to try some singlehanded racing in the future. Next question: Given the lack of space in the GBE cockpit, I'm thinking about installing it so the automatic tiller device runs fore & aft connecting to an extension running 90 degrees off the tiller. I realise this would put the compass bearing 90 degrees out, but if the trigonometry was correct, it would work as expected. Any thoughts on that idea? Anyone done it or something similar? Also, the tillerpilots seem to have fairly specific instructions on where the connection point needs to be along the length of the tiller. I'm assuming that if you go further along the tiller - increasing the distance between the stock and the connection point - the worst thing that would happen is that the turning circle wouldn't be tight as expected (which would be desirable for a setup where you're cruising along at multihull speeds). Quote Link to post Share on other sites
mattm 98 Posted September 20, 2019 Share Posted September 20, 2019 Being turned 90 shouldn’t matter, the tiller pilot doesn’t really need to know where north is, just a reference heading and weather it’s to port or starboard of that. Shifting the connection further out the tiller will also make it turn the rudder slower, as it will need to extend further to make the same amount of change as if it were closer to the stock. Also, the turning circle being bigger, although I don’t see that as much of a benefit, but the ram will have more leverage. I’d think speed of turn would be a fair priority. Quote Link to post Share on other sites
Clipper 343 Posted September 20, 2019 Share Posted September 20, 2019 Mine was fitted under the crossbar between the tillers. One end on the hill side and the other under the bar. It meant the pilot was twice as far from the pivot it should have been (800mm v 400mm??). Other than slower reactions, not too much of an issue. I did find the ST2000 was much faster than the ST1000, which helped. The cats dont need much movement of the tiller, they track well as it is, and at pace, you dont move the tiller anywhere near as much as a mono. Quote Link to post Share on other sites
Island Time 1,227 Posted September 20, 2019 Share Posted September 20, 2019 If you use a tillerpilot, they all have a fairly crap compass anyway. If you use a TP22 or 32, you can add an external compass, correctly oriented. They steer a hell of a lot better with that, even better if you interface wind instruments, then you can steer to wind angles. Add a MFD, like the Vulcan or Zeus 3, and you have a fully functional nav system with autopilot. Quote Link to post Share on other sites
mattm 98 Posted September 20, 2019 Share Posted September 20, 2019 The system on my boat is as you suggest IT, and it’s awesome. TP32, Vulcan plotter, triton instrument system, external compass and wireless AP remote. It drives the boat amazingly well, I can use the buttons on the TP or the full controls on the Vulcan to operate the AP, and the remote is great. It’s also handy to set it to wind angle, then set it to 0 degrees when dropping the main, doesn’t matter if the wind shifts, boat stays head to wind. Quote Link to post Share on other sites
NZTiger 17 Posted September 20, 2019 Author Share Posted September 20, 2019 Yeah, that would be the holy grail of setups. I think I drooled on my keyboard while reading those posts. My budget will constrain me to something simple to start with but will ensure that whatever I go with can be upgraded to the wizardry that you speak of. Quote Link to post Share on other sites
ex TL systems 63 Posted September 20, 2019 Share Posted September 20, 2019 I had a basic st 2000 on a 36 ft Mitchell cat was fitted about 5ft along the tiller because that’s what was easy. Worked fine to keep course but i never tried to tack with it. Loads on the pilot were minimal. Quote Link to post Share on other sites
ex TL systems 63 Posted September 20, 2019 Share Posted September 20, 2019 Look up pelagic pilots they look good. Quote Link to post Share on other sites
Cantab 341 Posted September 20, 2019 Share Posted September 20, 2019 The Pelagic is worth looking at, I got one and am astounded at how well it controls the boat off the wind. More than happy to run spinnaker or gennaker with it under control in good breeze with waves. Lets you trim while the pilot steers. Couldn't do that safely before with the old tiller pilot. Wireless Remote Control with 2, 10, 25 and 95 degree course change, can steer to wind too but I haven't got that set up yet. Adjustable response to course, and boat yaw response plus overall gain adjustment. Not much dearer than a tiller pilot and in another league for performance. Very good email support from manufacturer, you can talk to them on the phone too if you need to - that's the people that actually develop and make them. https://www.scanmarinternational.com/pelagic-autopilot Website a little bit confusing, would pay to email them about what you want, the remote is essential. Quote Link to post Share on other sites
Bradz 18 Posted September 20, 2019 Share Posted September 20, 2019 +1 for the Pelagic, we have the actuator running off B&G NAC3. This was to be a cheaper option before going to a hydraulic drive. Very impressed so far, the hydraulic upgrade has been almost forgotten about. Quote Link to post Share on other sites
NZTiger 17 Posted September 25, 2019 Author Share Posted September 25, 2019 I'll definitely check the Pelagic out. Does the Pelagic setup require a separate base unit for wireless connectivity? or is it integrated into the standard setup? The website seems to sell a remote without a base unit. Quote Link to post Share on other sites
Bradz 18 Posted September 25, 2019 Share Posted September 25, 2019 I'd get in contact with them for any queries, very helpful and prompt reply, Brian is who you want to get in touch with. pelagicautopilot@gmail.com Quote Link to post Share on other sites
NZTiger 17 Posted September 25, 2019 Author Share Posted September 25, 2019 I'd get in contact with them for any queries, very helpful and prompt reply, Brian is who you want to get in touch with. pelagicautopilot@gmail.com Thanks for that. I'll give them a try. Quote Link to post Share on other sites
Cantab 341 Posted September 25, 2019 Share Posted September 25, 2019 The control head deals with everything, wireless remote included. Just note these pilots do not interface with your GPS etc, they will take a specific wind sentence in nmea 0183 for steer to wind. It also takes a bit to get your head around the adjustments, but if your setup is pretty standard the latest version will work straight out of the box. PM your email address I can send you a manual. Quote Link to post Share on other sites
